rs485 huanyang speed control
8 years 4 months ago - 8 years 4 months ago #112944 by BrendaEM
Replied by BrendaEM on topic rs485 huanyang speed control
Yes, I am using Axis.
I guess it thinks I have no spindle, so I guess I have to do another round with stepconf, and then the merging, and the sorting, with the pointy teeth : P
And I don't have any idea what stepconf settings applies to the Huanyang VFDs. In the video Marco Reps just glosses over the spindle page in stepconf--not important : P I like his videos, though.
My thinking is: most people will have a milling machine with a spindle.
Oh, the Axis internal controls are written in different language than the external ones....
One of the shames about Axis is: nothing is anti-aliased--no Cairo?
Thanks,
Brenda
Last edit: 8 years 4 months ago by BrendaEM.
8 years 4 months ago - 8 years 4 months ago #112946 by andypugh
Replied by andypugh on topic rs485 huanyang speed control
Maybe now is the time to decide that Stepconf has done its duty and its time to take charge of your HAL and INI yourself.
Back in the mists of time the HAL and INI had to be written from scratch. Stepconf and PnCCOnf are "wizards" that try to automate the process, but the HAL and INI are meant to be human-readable and are expected to be human-edited.
To put this in perspective, I wrote about half of the Mesa drivers, but I have never used PnCConf. (largely because I am nearly always working with new cards that PnCConf can't be expected to work with because _LinuxCNC_ doesn't work with them yet.)
Last edit: 8 years 4 months ago by andypugh.
8 years 4 months ago - 8 years 4 months ago #112949 by BrendaEM
Well, as you know know most of my .hal is custom; you helped me with it : )
I just don't know what form of communication is happening over RS285.
Is RS285 sending PWM or data?
To read the hy_vfd man page, I would think that it sends and read data to/from the VFD, but the spindle control code I've seen seems to deal with terminal PWM, so how can it work?
It appears that stepconf has a PDM option, will that help it's speed settings work for RS485
In general the thing missing from the LinuxCNC documentation is examples of use and a sense of how things fit together, a lay of the land. A user who does not understand the documentation enough to soldier through it cannot improve it, and they will come here to the forums.
This would be a swell place to include some Huanyang VFD information.
wiki.linuxcnc.org/cgi-bin/wiki.pl?VFD_Modbus
  • ozzyrob
  • Visitor
  • Visitor
8 years 4 months ago - 8 years 4 months ago #112952 by ozzyrob
Replied by ozzyrob on topic rs485 huanyang speed control
RS-485 and the rest explained....it's data.
www.ni.com/white-paper/11390/en/
There's the man pages ;)
linuxcnc.org/docs/2.7/html/man/man1/hy_vfd.1.html
linuxcnc.org/docs/2.7/html/man/man1/hy_gt_vfd.1.html
And probably more info available by searching the forum.
Last edit: 8 years 4 months ago by ozzyrob.
8 years 4 months ago - 8 years 4 months ago #112954 by BrendaEM
I've seen serial protocol before.
The issue I am having is: having never seen working code, having never found anything that explains how the speed setting connect with HY VFD, this I am shooting in the quiet dark.
Noticing that the VFD driver was written to support a Huanyang GT just sent a chill down my spine.
8 years 4 months ago - 8 years 4 months ago #112955 by andypugh
BrendaEM wrote: I just don't know what form of communication is happening over RS285.
It is sending numerical data. (it's a byte-based serial protocol, sending PWM would be weird. And also entirely possible)
HAL is magic. Or close. Everything in HAL is just a number. Most of the important ones are floats. But you can convert them in HAL. Most simply with the dedicated functions like "conv_float_s32" but more subtly with things like the "PWM" HAL module that takes a floating-point spindle speed as input and outputs a bit-type output for connection to a digital pin.
In your case you would just not have the PWM component. Simply connect floating-point spindle speed command to the VFD component floating-point spindle-speed input.
Unless you need scaling.
Time to create page: 1.977 seconds
