rs485 huanyang speed control
8 years 4 months ago - 8 years 4 months ago #113141 by BrendaEM
Replied by BrendaEM on topic rs485 huanyang speed control
Eureka!!! I found the problem!!!
Donning safety google, because I am now sitting pretty close to the spindle, I energized the system, and launched LinuxCNC...
While probing the spindle-command-rpm-abs signal, I clicked on the RPM increase until I got over 6600. As soon as I passed it, the motor RPM went up, and the at-speed indicator finally went green. : )
The system was sending correctly scaled RPM commands, but the sent speed was lower than the user-set VFD minimum, so that is what it was giving me. (Apparently, Huanyang air-cooled spindles motors don't like running under 110Hz, the water-cooled ones below 100hz, so I had indeed set those values.)
Editing the custompanel.xml control, changing the 3000 to 24000, fixed the visual widget issue.
The too-many-clicks issue was lessened by editing the .ini [DISPLAY] section, adding:
DEFAULT_SPINDLE_SPEED = 6600
Ref: forum.linuxcnc.org/21-axis/34056-spindle...nimum-starting-value
Though, the build code would have to be changed in Axis to change the increments, from what I have read, which likely should have been a ini variable.
I've removed all the classic ladder and PWM statements from my .hal.
Thank you all who helped me : )
Last edit: 8 years 4 months ago by BrendaEM.
8 years 4 months ago #113145 by andypugh
Replied by andypugh on topic rs485 huanyang speed control
Use MDI and M3 commands to set the spindle speed directly.
Normally the correct spindle speed will be set by the G-code.
M3 S20000
The following user(s) said Thank You: BrendaEM
8 years 4 months ago - 8 years 4 months ago #113149 by BrendaEM
I thought my first cut would be manual, but I used NativeCam to cut a pocket in a scrap of plywood.
It made chips! :woohoo:
Thank you again!
Time to create page: 3.802 seconds
