(SOLVED - maybe) How to get an underscore in a pin/parameter name?
14 Jun 2018 16:10 #112360 by andypugh
Create your component and then pre-process
halcompile --preprocess hm2_7i76e.comp
Then edit the generated C file to have your pin names.
Then compile and install
sudo halcompile --install hm2_7i76e.c
14 Jun 2018 16:11 #112361 by andypugh
But, on a typical LinuxCNC intallation you can simply change the [HOSTMOT2[BOARD string to be your hm2-7i76 module and edit the loadrt lines.
14 Jun 2018 16:13 #112362 by andypugh
  • Sparky961
  • Sparky961's Avatar Topic Author
  • Elite Member
  • Elite Member
14 Jun 2018 17:24 #112363 by Sparky961
I'd be putting my wager on the coder doing something wrong rather than the compiler doing something wrong
Just cos a underscore can be used does not necessarily mean it should.
Not at all helpful.
  • Sparky961
  • Elite Member
  • Elite Member
14 Jun 2018 17:26 #112364 by Sparky961
Perhaps you missed where I showed doing exactly the same...
forum.linuxcnc.org/24-hal-components/347...?limitstart=0#112340
14 Jun 2018 17:30 #112365 by andypugh
That doesn't seem to be exactly the same thing at all. Perhaps you failed to read my recipe?
(And you will find that you get the problem you describe any time that the component name and the file name do not match, so if you didn't change the component name in supply.c then it simply won't work.)
  • Sparky961
  • Elite Member
  • Elite Member
14 Jun 2018 17:36 #112366 by Sparky961
I don't suppose hm2_test is any help?
github.com/LinuxCNC/linuxcnc/blob/master...-hostmot2/hm2_test.c
It looks promising. If it allows me to run a config offline it is a viable solution.
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
14 Jun 2018 17:38 #112367 by ozzyrob
That's what I was trying to say, the file name and component name have to match, hence the coding error.
What is the thing with the dash replacing underscore if you know ?
14 Jun 2018 17:45 #112368 by andypugh
Part of the (widely ignored) canonical interface specification.
It is documented somewhere that all HAL pins should use hyphens.
The following user(s) said Thank You: ozzyrob
14 Jun 2018 17:46 #112369 by andypugh
It looks promising. If it allows me to run a config offline it is a viable solution.[/quote]
Having tried it, I am not sure if any of the test_patterns actually load.
halrun
loadrt hostmot2
loadrt hm2_test test_pattern=6
For example.
Time to create page: 1.022 seconds
