(SOLVED - maybe) How to get an underscore in a pin/parameter name?
- Sparky961
- Thank you received: 15
14 Jun 2018 18:55 #112370
by Sparky961
Replied by Sparky961 on topic How to get an underscore in a pin/parameter name?
Looking back, I grabbed the wrong link. Here's the one where I preprocess, modify, them compile:
forum.linuxcnc.org/24-hal-components/347...?limitstart=0#112343
- ozzyrob
- Visitor
14 Jun 2018 22:29 #112380
by ozzyrob
Yes you are right in that context probably not....but you did decide to leave out this bit as to why it might be an error on the coder's part.
Replied by ozzyrob on topic How to get an underscore in a pin/parameter name?
I'd be putting my wager on the coder doing something wrong rather than the compiler doing something wrong
Just cos a underscore can be used does not necessarily mean it should.
Not at all helpful.
Make sure that all the component names in the file match the source file name...I got the same behavior when I copied the supply.c src to supply_2.c and didn't change any reference to supply to supply_2.
- Sparky961
14 Jun 2018 23:44 #112384
by Sparky961
I left it out because a few posts later my course changed and I'm not trying to compile an existing file with changed names anymore.
Keep up mate, you're getting left behind. As confusing as it may be to those who might be gracious enough to help me, I can't possibly wait helplessly for people to respond. I have to keep trying things and move forward.
As to the argument of whether or not to use an underscore, it isn't my choice. The existing component I'm trying to make a "dummy" of has names with underscores.
The present issue, also mentioned previously in this thread, is that I can't seem to get a working component through the two-step process of using halcompile to preprocess the *.comp file, then 'halcompile --install' the generated C file after changing only one character in the file - the dash to an underscore.
I'll be investigating that one after I submit this. That, or I might do something more useful since this was supposed to be yet another "quick side project".
- Sparky961
15 Jun 2018 00:00 #112385
by Sparky961
So here's a thought:
Are there different versions of components, halcompile, and whatever else needed to build components for 'uspace' or for the rt-preempt kernel I installed? If so, how to I verify what I have and correct any mismatch?
- Sparky961
15 Jun 2018 00:22 - 15 Jun 2018 02:23 #112386
by Sparky961
For the sake of completeness, I'll summarize the current issue.
I make a file, 'and5.comp' that's in the component generator language:
Then I run the following:
Ok, all seems well. Then I try to load it in HAL:
...ok, this also seems to be working fine.
Now when I try to do it in two steps:
Then only preprocess:
Results in hm2_7i76e.c being created as below:
Now I change only the dash in the name on line 56 to an underscore and try to compile the C file:
No nasty errors. Seems like it worked.
Now, as before, I try to load the component in HAL:
Well I'll be a ...... damn. I swear that wasn't happening last night. It would try to load and never succeed.
Seems I don't need help on this anymore for the time being. Unless I can reproduce the problem, it seems.
component and5 "Five-input AND gate";
pin in bit in0;
pin in bit in1;
pin in bit in2;
pin in bit in3;
pin in bit in4;
pin out bit out;
function _ nofp;
license "GPL";
FUNCTION(_) { out = in0 && in1 && in2 && in3 && in4; }Then I run the following:
linuxcnc@debian:/usr/src/linuxcnc-dev/src/hal/components$ sudo halcompile --install and5.comp
[sudo] password for linuxcnc:
Compiling realtime and5.c
Linking and5.so
cp and5.so /usr/lib/linuxcnc/modules/Ok, all seems well. Then I try to load it in HAL:
linuxcnc@debian:/usr/src/linuxcnc-dev/src/hal/components$ halrun
halcmd: loadrt and5
Note: Using POSIX realtime
halcmd: show
Loaded HAL Components:
ID Type Name PID State
6 RT and5 ready
4 User halcmd3948 3948 ready
Component Pins:
Owner Type Dir Value Name
6 bit IN FALSE and5.0.in0
6 bit IN FALSE and5.0.in1
6 bit IN FALSE and5.0.in2
6 bit IN FALSE and5.0.in3
6 bit IN FALSE and5.0.in4
6 bit OUT FALSE and5.0.out
6 s32 OUT 0 and5.0.time
<snip>...ok, this also seems to be working fine.
component hm2_7i76e "Fake pins from 7i76e for testing without attached hardware";
param r s32 watchdog.timeout_ns = 5000000;
pin out bit out0;
pin in bit in0;
function _;
license "GPL";
FUNCTION(_) {
}Then only preprocess:
linuxcnc@debian:/usr/src/linuxcnc-dev/src/hal/components$ sudo halcompile --preprocess hm2_7i76e.compResults in hm2_7i76e.c being created as below:
/* Autogenerated by /usr/bin/halcompile on Thu Jun 14 20:12:52 2018 -- do not edit */
#include "rtapi.h"
#ifdef RTAPI
#include "rtapi_app.h"
#endif
#include "rtapi_string.h"
#include "rtapi_errno.h"
#include "hal.h"
#include "rtapi_math64.h"
static int comp_id;
#ifdef MODULE_INFO
MODULE_INFO(linuxcnc, "component:hm2_7i76e:Fake pins from 7i76e for testing without attached hardware");
MODULE_INFO(linuxcnc, "param:watchdog.timeout_ns:s32:0:r::5000000:None");
MODULE_INFO(linuxcnc, "pin:out0:bit:0:out::None:None");
MODULE_INFO(linuxcnc, "pin:in0:bit:0:in::None:None");
MODULE_INFO(linuxcnc, "funct:_:1:");
MODULE_INFO(linuxcnc, "license:GPL");
MODULE_LICENSE("GPL");
#endif // MODULE_INFO
struct __comp_state {
struct __comp_state *_next;
hal_bit_t *out0;
hal_bit_t *in0;
hal_s32_t watchdog_timeout_ns;
struct __comp_state *__comp_first_inst=0, *__comp_last_inst=0;
static void _(struct __comp_state *__comp_inst, long period);
static int __comp_get_data_size(void);
#undef TRUE
#define TRUE (1)
#undef FALSE
#define FALSE (0)
#undef true
#define true (1)
#undef false
#define false (0)
static int export(char *prefix, long extra_arg) {
char buf[HAL_NAME_LEN + 1];
int r = 0;
int sz = sizeof(struct __comp_state) + __comp_get_data_size();
struct __comp_state *inst = hal_malloc(sz);
memset(inst, 0, sz);
r = hal_pin_bit_newf(HAL_OUT, &(inst->out0), comp_id,
"%s.out0", prefix);
if(r != 0) return r;
r = hal_pin_bit_newf(HAL_IN, &(inst->in0), comp_id,
"%s.in0", prefix);
r = hal_param_s32_newf(HAL_RO, &(inst->watchdog_timeout_ns), comp_id,
"%s.watchdog.timeout-ns", prefix);
inst->watchdog_timeout_ns = 5000000;
rtapi_snprintf(buf, sizeof(buf), "%s", prefix);
r = hal_export_funct(buf, (void(*)(void *inst, long))_, inst, 1, 0, comp_id);
if(__comp_last_inst) __comp_last_inst->_next = inst;
__comp_last_inst = inst;
if(!__comp_first_inst) __comp_first_inst = inst;
return 0;
static int default_count=1, count=0;
char *names[16] = {0,};
RTAPI_MP_INT(count, "number of hm2_7i76e");
RTAPI_MP_ARRAY_STRING(names, 16, "names of hm2_7i76e");
int rtapi_app_main(void) {
int r = 0;
int i;
comp_id = hal_init("hm2_7i76e");
if(comp_id < 0) return comp_id;
if(count && names[0]) {
rtapi_print_msg(RTAPI_MSG_ERR,"count= and names= are mutually exclusive\n");
return -EINVAL;
if(!count && !names[0]) count = default_count;
if(count) {
for(i=0; i<count; i++) {
rtapi_snprintf(buf, sizeof(buf), "hm2-7i76e.%d", i);
r = export(buf, i);
if(r != 0) break;
} else {
int max_names = sizeof(names)/sizeof(names[0]);
for(i=0; (i < max_names) && names[i]; i++) {
if (strlen(names[i]) < 1) {
rtapi_print_msg(RTAPI_MSG_ERR, "names[%d] is invalid (empty string)\n", i);
r = -EINVAL;
break;
r = export(names[i], i);
if(r != 0) break;
if(r) {
hal_exit(comp_id);
} else {
hal_ready(comp_id);
return r;
void rtapi_app_exit(void) {
hal_exit(comp_id);
#undef FUNCTION
#define FUNCTION(name) static void name(struct __comp_state *__comp_inst, long period)
#undef EXTRA_SETUP
#define EXTRA_SETUP() static int extra_setup(struct __comp_state *__comp_inst, char *prefix, long extra_arg)
#undef EXTRA_CLEANUP
#define EXTRA_CLEANUP() static void extra_cleanup(void)
#undef fperiod
#define fperiod (period * 1e-9)
#undef out0
#define out0 (*__comp_inst->out0)
#undef in0
#define in0 (0+*__comp_inst->in0)
#undef watchdog_timeout_ns
#define watchdog_timeout_ns (__comp_inst->watchdog_timeout_ns)
#line 8 "hm2_7i76e.comp"
FUNCTION(_) {
static int __comp_get_data_size(void) { return 0; }Now I change only the dash in the name on line 56 to an underscore and try to compile the C file:
linuxcnc@debian:/usr/src/linuxcnc-dev/src/hal/components$ sudo halcompile --install hm2_7i76e.c
Compiling realtime hm2_7i76e.c
Linking hm2_7i76e.so
cp hm2_7i76e.so /usr/lib/linuxcnc/modules/No nasty errors. Seems like it worked.
halcmd: loadrt hm2_7i76e
halcmd: show
6 RT hm2_7i76e ready
4 User halcmd4023 4023 ready
Component Pins:
6 bit IN FALSE hm2-7i76e.0.in0
6 bit OUT FALSE hm2-7i76e.0.out0
6 s32 OUT 0 hm2-7i76e.0.time
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
Parameters:
6 s32 RW 0 hm2-7i76e.0.tmax
6 bit RO FALSE hm2-7i76e.0.tmax-increased
6 s32 RO 5000000 hm2-7i76e.0.watchdog.timeout_nsSeems I don't need help on this anymore for the time being. Unless I can reproduce the problem, it seems.
Last edit: 15 Jun 2018 02:23 by Sparky961. Reason: Missed word...
- ozzyrob
- Visitor
15 Jun 2018 01:07 #112387
by ozzyrob
Apparently you can use any string for indicated in red:
As seen here in blue:
"%s.foofoo.dog_woof", prefix);
halcmd: show
4 User halcmd9484 9484 ready
Component Pins:
Pin Aliases:
Alias Original Name
Signals:
Parameters:
6 s32 RO 5000000 hm2-7i76e.0.foofoo.dog_woof
Parameter Aliases:
Alias Original Name
Exported Functions:
Owner CodeAddr Arg FP Users Name
00006 7f158155bcb0 7f1582d640d8 YES 0 hm2-7i76e.0
Realtime Threads:
Period FP Name ( Time, Max-Time )
halcmd: quit
halcmd: show
Component Pins:
Pin Aliases:
Alias Original Name
Signals:
Parameters:
Parameter Aliases:
Alias Original Name
Exported Functions:
Realtime Threads:
halcmd: quit
15 Jun 2018 09:12 #112394
Replied by andypugh on topic How to get an underscore in a pin/parameter name?
Do you want pins "hm2_7i76" or "hm2-7i76" ?
The real HAL file with the real 7i76 will have "hm2_7i76" (maybe hm2_7i76e" I haven't seen one)
- Sparky961
15 Jun 2018 10:35 #112395
by Sparky961
Yes, you're right. I was so focused on the one I didn't see the other.
Time to create page: 0.309 seconds
