(SOLVED - maybe) How to get an underscore in a pin/parameter name?
github.com/LinuxCNC/linuxcnc/blob/master...-hostmot2/hm2_test.c
- Sparky961
- Thank you received: 15
ozzyrob wrote: I'd be putting my wager on the coder doing something wrong rather than the compiler doing something wrong
Just cos a underscore can be used does not necessarily mean it should.
Not at all helpful.
- Sparky961
andypugh wrote: Create your component and then pre-process
Code:halcompile --preprocess hm2_7i76e.comp
Then edit the generated C file to have your pin names.
Then compile and install
Code:sudo halcompile --install hm2_7i76e.c
Perhaps you missed where I showed doing exactly the same...
forum.linuxcnc.org/24-hal-components/347...?limitstart=0#112340
Sparky961 wrote: Perhaps you missed where I showed doing exactly the same...
That doesn't seem to be exactly the same thing at all. Perhaps you failed to read my recipe?
(And you will find that you get the problem you describe any time that the component name and the file name do not match, so if you didn't change the component name in supply.c then it simply won't work.)
- Sparky961
andypugh wrote: I don't suppose hm2_test is any help?
It looks promising. If it allows me to run a config offline it is a viable solution.
- ozzyrob
- Visitor
What is the thing with the dash replacing underscore if you know ?
