hy_VFD hy_VFD vfd.speed-command not setting RPM
03 Aug 2018 19:02 - 03 Aug 2018 19:03 #115566 by andypugh
[Or even some generic two-core shielded microphone cable. RS485 is, by design a fairly robust protocol, so you don't need to spend a fortune on premium shielded cables to get reliable performance.
I partly used DMX because I found it in purple, and that made it more obvious in the wiring scheme. And I like to wire in orange, pink and purple so that nobody makes assumptions about what a wire is.
Last edit: 03 Aug 2018 19:03 by andypugh.
03 Aug 2018 21:15 - 03 Aug 2018 21:20 #115578 by vre
I have connected pc with huanyang vfd with this adapter
www.ebay.com/itm/RS-232-RS232-to-RS-485-...ter-NEW/141699993928
with simple cat5 cable (about 4 meters length) without termination resistors
and works very good.
One usb adapter i have tried had issues.
Last edit: 03 Aug 2018 21:20 by vre.
Time to create page: 0.470 seconds
