Plasma THC
8 years 2 months ago #116859 by tommylight
Replied by tommylight on topic Plasma THC
Well, in case of the SD you have no control over it, it has it's own memory to return to it's previous position after each cut, it has no ARCOK or any other signal at all.
The good thing is - it is easy to set up and use
The bad thing is - there is no way to control it from linuxcnc.
You need a simple config so that will make the installation and configuration easy.
7 years 5 months ago #133996 by vsjadhav
Replied by vsjadhav on topic Plasma THC
I am getting same message for all grotius gmoccupies I download.
How did you solved that problem of
Found file (REL):
7 years 5 months ago #134224 by tommylight
vsjadhav wrote: I am getting same message for all grotius gmoccupies I download.
Found file (REL):
More info please.
What THC? What config etc?
7 years 5 months ago #134242 by vsjadhav
I was trying to run gmoccupy from grotius, just running, no hardwares attached. It is not executing, it terminates with error
Found file (REL): ./stepper.hal
If I put # in front of stepper.hal in .ini then,
It terminates with same message, but with next hal file which is there in .ini
For ex.
Found file (REL): ./something.hal
Shutting down linuxcnc
Another question,
Also downloaded your config toma-thc, it runs, but after opening gui, I am unable to shut down estop button, so can't power on and play with some programs.
By the way that I will be using will be self made as guided by Adrian on his utube channel, that is with LM393 4 channel votage comparator, it will be having arc ok, arc up and arc down outputs as required by your configs.
7 years 5 months ago #134300 by tommylight
You should read through the original thread of the THC_toma config or download the new version I uploaded some 2 months ago, but I might have uploaded the version for Linuxcnc 2.8 that will not work with older versions of Linuxcnc. The e-stop issue was encountered by user bosniacnc so you might find it faster if you search the forum by user name.
Time to create page: 0.070 seconds
