Plasma THC
8 years 2 months ago #115935 by Grotius
Replied by Grotius on topic Plasma THC
@David,
Your HF start wil demolishing every piece of electronic chip in and around near your plasma machine environment within no time.
Please don't do this at all, you are risking your 7i96 board.
Try to get a pilot start plasma first.
Why did you buy the Mesa card?
8 years 2 months ago #115940 by rodw
Replied by rodw on topic Plasma THC
The Mesa THCAD card is promoted as being OK in a HF start environment. If you mount it on the plasma machine, and the 7i96 further away, the output is a frequency so should be pretty immune to noise and then you can put your PC up to 100 metres further away via ethernet. Well anyway thats the theory. But yes, blowback torches are so much better for CNC.
8 years 2 months ago #115982 by snugglylovemuffin
Replied by snugglylovemuffin on topic Plasma THC
Exactly what rodw said, the mesa 7i96 is marketed as being hardened against electrical noise, which is why I bought it, as well as the board suported dual axis endstops for calibrating my gantry. I would love to upgrade plasma cutters but that comes at the cost of $1K+; not to get too much into it, I started this project with someone else, I alone am finishing it. The plasma cutter was just what I had.
I will upgrade my torch ASAP, however as far as I can tell this setup should work for now. I've got my controller and plasma on two different circuits to mitigate back emf, I'm using shielded cables and am grounding my controller enclosure.
8 years 2 months ago #115984 by rodw
Find the Hypertherm tech note on grounding and follow it. basically, they say to ground everything back to a "star" ground on the table frame including separate ground wires from every motor back to that point. The material grounding lead from the plasma cutter should be connected to this point as well. Hang on, I found it.This will be much more important for your HF machine.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
The following user(s) said Thank You: snugglylovemuffin
8 years 2 months ago #116050 by snugglylovemuffin
My neighbors getting a hypertherm 30xp, maybe I'll see if I can borrow it and buy a machine torch lol.
Thanks for the info, I'm definitely not going to cut corners protecting my electronics.
8 years 2 months ago #116107 by snugglylovemuffin
I'm wiring up the THCUD components and I'm not quite sure how to handle some of the lines; motion-vel or how to write in the offset. Could I please have an example?
Time to create page: 0.146 seconds
