- Thank you received: 11
Plasma THC
- snugglylovemuffin
- Topic Author
8 years 2 months ago #115543
by snugglylovemuffin
Plasma THC was created by snugglylovemuffin
Looking for some examples, information, regarding the integration of a THC (Proma 150) into a mesa ethernet context.
8 years 2 months ago #115546
Replied by rodw on topic Plasma THC
There is a component designed to work with a proma. Its not specific to mesa and should be simple to install
linuxcnc.org/docs/html/man/man9/thcud.9.html
BigJohnT may have an example gui on his web site
gnipsel.com/shop/plasma/plasma.xhtml
The following user(s) said Thank You: snugglylovemuffin
- snugglylovemuffin
- Topic Author
8 years 2 months ago #115895
Replied by snugglylovemuffin on topic Plasma THC
I adapted Tommylight's plasma config to my purposes. Went smoother, but I'm still getting about a thousand errors still. "joint.3.pos-cmd" (in the THC hal) already linked to "z-pos-cmd" (in machine hal)
Comment out the z-pos-cmd and then I get a ddt.0 pin "does not exist"
This is ridiculous; I appreciate where I was going wrong before, but as I stated this takes a much deeper appreciation for the function of the individual functions.
8 years 2 months ago #115900
by Grotius
Replied by Grotius on topic Plasma THC
Hi David,
The Toma code is designed for parport stepper motor control.
This is i think the reason Tommylight still uses a z axis stepper motor control with this Toma code.
So it's important to use the orginal Toma code, otherwise it will not work. In the installation example you see how to couple
the z axis, normally parport pin 6 and 7. You can try to change this into your mesa config, but let the Toma code untouched.
Change only the parport signal into what you want.
The following user(s) said Thank You: tommylight, snugglylovemuffin
8 years 2 months ago #115902
That is true, this is the only reason why i use stepper motors for Z axis on servo machines. Never got the time to make it work with servo motors.
Replied by tommylight on topic Plasma THC
Grotius wrote: This is i think the reason Tommylight still uses a z axis stepper motor control with this Toma code.
The following user(s) said Thank You: Grotius, snugglylovemuffin
8 years 2 months ago - 8 years 2 months ago #115906
by Grotius
If i look at this piece of Toma code :
The Toma architecture is based on stepgen. This is stepper motor control.
Maybe there is a trick to make from stepgen a servo controlled z axis. A sort of conversion step will do the work.
But this step is outside the Toma code !!!!
The working solution can be looking like this :
A more usefull code design :
The second code design, is a conversion from stepper to servo signal.
Maybe PCW knows a solution.
I can help to write a short component, because my time is limited.
net StepZ stepgen.2.step => parport.0.pin-06-out
net DirZ stepgen.2.dir => parport.0.pin-07-out
net Conversion_StepZ_in stepgen.2.step => Servo_Z_step_in
net Conversion_DirZ_in stepgen.2.dir => Servo_Z_dir_in
//So here in the middle the conversion step from stepper to servo will take place.
//It's a component that will do the work.
net Conversion_StepZ_out Servo_Z_step_out => stepgen.2.step
net Conversion_DirZ_out Servo_Z_step_out => stepgen.2.dir
net 1 stepgen.2.step => servo_Z_step_in
net 2 stepgen.2.dir => servo_Z_dir_in
net 3 servo_Z_step_out => stepgen.2.step
net 4 servo_Z_step_out => stepgen.2.dir
Last edit: 8 years 2 months ago by Grotius.
Time to create page: 0.232 seconds
