Plasma THC
  • Moderator
  • Moderator
18 May 2019 22:46 #134224 by tommylight
Replied by tommylight on topic Plasma THC
I am getting same message for all grotius gmoccupies I download.
How did you solved that problem of
Found file (REL):
More info please.
What THC? What config etc?
19 May 2019 06:42 #134242 by vsjadhav
Replied by vsjadhav on topic Plasma THC
I was trying to run gmoccupy from grotius, just running, no hardwares attached. It is not executing, it terminates with error
Found file (REL): ./stepper.hal
If I put # in front of stepper.hal in .ini then,
It terminates with same message, but with next hal file which is there in .ini
For ex.
Found file (REL): ./something.hal
Shutting down linuxcnc
Another question,
Also downloaded your config toma-thc, it runs, but after opening gui, I am unable to shut down estop button, so can't power on and play with some programs.
By the way that I will be using will be self made as guided by Adrian on his utube channel, that is with LM393 4 channel votage comparator, it will be having arc ok, arc up and arc down outputs as required by your configs.
  • Moderator
  • Moderator
19 May 2019 23:26 #134300 by tommylight
You should read through the original thread of the THC_toma config or download the new version I uploaded some 2 months ago, but I might have uploaded the version for Linuxcnc 2.8 that will not work with older versions of Linuxcnc. The e-stop issue was encountered by user bosniacnc so you might find it faster if you search the forum by user name.
