Plasma THC
11 Aug 2018 16:53 #115923 by PCW
Replied by PCW on topic Plasma THC
Rather than wading through Toma's Byzantine hal file, Why dont you start with the existing tchud component as rodw suggested a number of posts before. Thcud doesn't require access to any low level signals so it is applicable to servo, software stepper and hardware stepper systems. If it has deficiencies, fixing them would benefit anyone using a external up/down type THC device.
The following user(s) said Thank You: rodw, snugglylovemuffin
  • snugglylovemuffin
  • snugglylovemuffin's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Aug 2018 19:57 #115932 by snugglylovemuffin
Replied by snugglylovemuffin on topic Plasma THC
Okay, I'll see what I can do with THCUD; I suppose I'll learn how to add in the utilities as I learn the program.
@Grotius: I used PNCCONF to build a 7i76e before converting it to the 7i96, since there's no direct support for the board yet.
I do have a cheap parallel board and a parallel port card, but the torch I'm using has a HF start; which completely screws up the Arduino/GRBL board I was using...
I was trying to keep my rig away from the table, because I'm not yet running a water tray (long story), but I suppose this will have to work for now.
11 Aug 2018 20:31 #115935 by Grotius
Replied by Grotius on topic Plasma THC
@David,
Your HF start wil demolishing every piece of electronic chip in and around near your plasma machine environment within no time.
Please don't do this at all, you are risking your 7i96 board.
Try to get a pilot start plasma first.
Why did you buy the Mesa card?
11 Aug 2018 22:04 #115940 by rodw
Replied by rodw on topic Plasma THC
The Mesa THCAD card is promoted as being OK in a HF start environment. If you mount it on the plasma machine, and the 7i96 further away, the output is a frequency so should be pretty immune to noise and then you can put your PC up to 100 metres further away via ethernet. Well anyway thats the theory. But yes, blowback torches are so much better for CNC.
  • snugglylovemuffin
  • Elite Member
  • Elite Member
12 Aug 2018 17:45 #115982 by snugglylovemuffin
Exactly what rodw said, the mesa 7i96 is marketed as being hardened against electrical noise, which is why I bought it, as well as the board suported dual axis endstops for calibrating my gantry. I would love to upgrade plasma cutters but that comes at the cost of $1K+; not to get too much into it, I started this project with someone else, I alone am finishing it. The plasma cutter was just what I had.
I will upgrade my torch ASAP, however as far as I can tell this setup should work for now. I've got my controller and plasma on two different circuits to mitigate back emf, I'm using shielded cables and am grounding my controller enclosure.
12 Aug 2018 18:46 #115984 by rodw
Find the Hypertherm tech note on grounding and follow it. basically, they say to ground everything back to a "star" ground on the table frame including separate ground wires from every motor back to that point. The material grounding lead from the plasma cutter should be connected to this point as well. Hang on, I found it.This will be much more important for your HF machine.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
The following user(s) said Thank You: snugglylovemuffin
  • snugglylovemuffin
  • Elite Member
  • Elite Member
14 Aug 2018 10:06 #116050 by snugglylovemuffin
My neighbors getting a hypertherm 30xp, maybe I'll see if I can borrow it and buy a machine torch lol.
Thanks for the info, I'm definitely not going to cut corners protecting my electronics.
  • snugglylovemuffin
  • Elite Member
  • Elite Member
15 Aug 2018 18:52 #116107 by snugglylovemuffin
I'm wiring up the THCUD components and I'm not quite sure how to handle some of the lines; motion-vel or how to write in the offset. Could I please have an example?
18 Aug 2018 12:52 #116278 by Grotius
19 Aug 2018 13:22 - 19 Aug 2018 13:28 #116338 by Grotius
David,
You can connect your mesa if you want. Without connections, it also works.
The link is a special linuxcnc edition with a torch height controller. You can test this application and connect it easy
to your hardware.
read this carefully.
Last edit: 19 Aug 2018 13:28 by Grotius.
Time to create page: 0.508 seconds
