Message Component - Reset?
- phillc54
- Thank you received: 2100
04 Jan 2020 21:44 #154074
by phillc54
Replied by phillc54 on topic Message Component - Reset?
You will get that error if you have the HAL Configuration window open while Axis is exiting. The error is because HAL Configuration cannot find the pin because it was removed by Axis when it was exiting.
You could also achieve the same with the following in the .axisrc file in your home directory which allows you to update LinuxCNC without have to edit axis.py again.You could have a USER_COMMAND_FILE instead of .axisrc.
See sections 12.3, 12.4, 12.5 & 12.6 here: linuxcnc.org/docs/devel/html/gui/axis.html#_axisrc
def user_hal_pins():
comp.newpin('notifications', hal.HAL_BIT, hal.HAL_OUT)
comp.ready()
def user_live_update():
if len(notifications.widgets):
comp ["notifications"] = True
else:
comp ["notifications"] = FalseSee sections 12.3, 12.4, 12.5 & 12.6 here: linuxcnc.org/docs/devel/html/gui/axis.html#_axisrc
The following user(s) said Thank You: chimeno
- chimeno
- Thank you received: 125
07 Jan 2020 13:04 #154235
by chimeno
Replied by chimeno on topic Message Component - Reset?
Hi Phill,
Thank you very much for the answer, modify the code because the .axisrc file does not work for me, it is in the directory where I have the configuration files .ini and .hal, formerly if it worked for me, something else I should do, anyway add your code via USER_COMMAND_FILE and it works very well, I admire your work here in the forum!
thanks
Chimeno
thanks
Chimeno
- phillc54
07 Jan 2020 16:18 #154266
by phillc54
If you use .axisrc it needs to be in your home directory (I should have said ~/.axisrc). It is then used by every LinuxCNC config.
A USER_COMMAND_FILE allows you to define a different file for each config and it will take precedence over ~/.axisrc if you have both.
- chimeno
28 Jan 2020 14:37 - 28 Jan 2020 14:38 #156046
by chimeno
Hi Phill,
With your guide example I want to perform the PC shutdown by means of a hal-pin, how could a message appear on the screen "turning off PC" wait 5 seconds and turn off, for now this is what I have ...
tried with these but it just didn't work for me ..I get errors together, if you can help me with some guidance, thank you.
Greeting
Chimeno
comp.newpin('turn-off-machine', hal.HAL_BIT, hal.HAL_IN)
comp.newpin('turn-off-machine.is-on', hal.HAL_BIT, hal.HAL_OUT)
comp.ready()
if bool(comp["turn-off-machine"]):
comp ["turn-off-machine.is-on"] = False
else:
os.system('systemctl poweroff')time.sleep(5)
os.system('notify-send -t 10 -u low "turning off..."')
tkMessageBox.showinfo("turning off...", "power off")Greeting
Chimeno
Last edit: 28 Jan 2020 14:38 by chimeno.
- phillc54
05 Feb 2020 21:28 #156612
by phillc54
Sorry, I meant to reply earlier but I got a bit sidetracked.
I think the following will do what you want:
sdShow = False
sdCount = 0
sdSecs = '543210'
comp.ready()
global sdShow, sdCount, sdStart, sdLabel, sdWindow
if comp['turn-off-machine'] and s.interp_state == linuxcnc.INTERP_IDLE:
if not sdShow:
sdStart = time.time()
sdWindow = Tkinter.Toplevel(relief='ridge', borderwidth=4)
sdWindow.title('SHUTDOWN')
sdLabel = Tkinter.Label(sdWindow, fg='red', font='sans 16 bold')
sdLabel.pack()
sdShow = True
else:
if sdCount > 5:
sdWindow.destroy()
elif time.time() > sdStart + sdCount:
msg = 'Turning machine off in {} seconds'.format(sdSecs[sdCount])
sdLabel.config(text=msg)
sdCount += 1
elif sdShow:
sdWindow.destroy()
sdShow = False
sdCount = 0
- chimeno
09 Feb 2020 11:26 #156893
by chimeno
Hi @phillc54
Thank you very much for the help, I will study your example!
Chimeno
Chimeno
Time to create page: 0.108 seconds
