MPG on 7I76 in mode 2
7 years 8 months ago #126046 by Marco
MPG on 7I76 in mode 2 was created by Marco
i set 7i76 in mode2, i have wired the encoder on pin 16-17 (on tb5 pin 1-2) with 5vcc and common ground with field power and gnd stepper pin.
On HAL meter hm2_5i25.0.7i76.0.0.input-16/17 work.
i don't know which and how HAL file modify.
7 years 8 months ago #126053 by pl7i92
Replied by pl7i92 on topic MPG on 7I76 in mode 2
there is somthing wrong
you shoudt see in mode2
hm2_5i25.0.7i76.enc0 or enc1
this might be not setup the mode 2
7 years 8 months ago - 7 years 8 months ago #126055 by Marco
Replied by Marco on topic MPG on 7I76 in mode 2
yes, i see also hm2_5i25.0.7i76.enc0 and hm2_5i25.0.7i76.enc1 with all their parameters and hm2_5i25.0.7i76.enc0.count works on hal meter
Last edit: 7 years 8 months ago by Marco.
7 years 8 months ago #126135 by Marco
7 years 8 months ago #126136 by rodw
Replied by rodw on topic MPG on 7I76 in mode 2
I posted an example for the 7i76e here which should be simple to implement on your 7i76
forum.linuxcnc.org/show-your-stuff/32029...utter-build?start=20
and yes, your pins look right to me
7 years 8 months ago #126407 by andypugh
Replied by andypugh on topic MPG on 7I76 in mode 2
Maxardi99 wrote: yes, i see also hm2_5i25.0.7i76.enc0 and hm2_5i25.0.7i76.enc1 with all their parameters and hm2_5i25.0.7i76.enc0.count works on hal meter
What is the question?
Time to create page: 0.263 seconds
