XHC-WHB04-4 Python component
5 years 9 months ago - 5 years 9 months ago #196569 by fixer
Replied by fixer on topic XHC-WHB04-4 Python component
yes.
read realpython.com/python-boolean/
whb allows 2 simultaneous keys pressed, it returns the first pressed in [2] and the second in [3] this allows to have alternate key functionality with fn key...
Last edit: 5 years 9 months ago by fixer.
5 years 9 months ago #196573 by probotix
Ok, understand now. So, why do you have to check both data[2] and data[3]?
5 years 9 months ago #196575 by fixer
do a print(data) in line 180 and watch output in terminal while pressing different buttons on the pendant...
5 years 9 months ago #196577 by probotix
I couldn't come up with any combination of button presses that changed data[3], it appears to always be zero.
5 years 9 months ago #196579 by probotix
Also, have you come up with a way to identify button releases? I see the release events happen, but it doesn't appear to identify which button was released.
5 years 9 months ago #196602 by fixer
Release event is identified as data[2]==0
If you want to know which button was released you should first save the state of pressed buttons and compare it with the state in the next iteration of while(1)
