XHC-WHB04-4 Python component
7 years 2 months ago #143713 by serafim
Thanks, pl7i92. Can you or somebody share hal for the WHB04B? I can see that designated pins work but drives are not moving. I guess I'm missing some pin connection.
loadusr -W whb04b net axis0jogenable axis.x.jog-enable whb04b.sel_x net axis1jogenable axis.y.jog-enable whb04b.sel_y net axis2jogenable axis.z.jog-enable whb04b.sel_z net joginc whb04b.inc net joginc axis.x.jog-scale net joginc axis.y.jog-scale net joginc axis.z.jog-scale net jogcnts whb04b.mpg_cnt net jogcnts axis.x.jog-counts net jogcnts axis.y.jog-counts net jogcnts axis.z.jog-counts setp axis.x.jog-vel-mode 1 setp axis.y.jog-vel-mode 1 setp axis.z.jog-vel-mode 1
7 years 2 months ago #143727 by pl7i92
Replied by pl7i92 on topic XHC-WHB04-4 Python component
this is only the base connection
So do you got a COMP called whb04b
otherwise use the internal for the base XHC it will work for all pins
its alot more to be connected to run the B version
WHERE are the BUTTONS Discribed INI file
loadusr -W xhc-hb04 -H -I wbcnc_2.7.9.ini -s 4
linuxcnc.org/docs/html/man/man1/xhc-hb04.1.html
you need to understand how the postgui system workes together with HALUI
Get signal from external and do somthing in the servo tread time
6 years 5 months ago #167967 by fixer
Replied by fixer on topic XHC-WHB04-4 Python component
I edited fist post, component is now on github.
It does behave a bit different, it produces much less traffic on the USB bus than the "official" driver.
5 years 9 months ago #196547 by probotix
Good job on this. I have it running on 2.8.1
Can you explain this syntax for me?
h.fn = data[2] == 12 or data[3] == 12
Also, when running inches, the 1.0 jog increments only moves 0.48 inches. Any ideas?
5 years 9 months ago #196559 by fixer
sure.
h.fn is output pin of self hal component. "data" structure contains received data from whb device. Fields [2] and [3] are pressed buttons, value 12 means fn button pressed.
on metric inrements are 1mm, 0.1mm, 0.01mm, 0.001mm. On imperial each should be divided by 10 - line 196
can you check with halshow whb inc and axis jog-scale pins? what do they show on your configuration. Show your hal files so I can check.
5 years 9 months ago - 5 years 9 months ago #196568 by probotix
Sorry let me clarify my question. I don't have a full understanding of the python syntax, yet. I'm trying to understand the a = b == x or c == x syntax. I know what a,b,c, and x are, just not what the equals signs and or mean when combined like that. does it mean that a is true if either b == x or c == x.
If so, why do you have to check both data[2] and data[3]?
Last edit: 5 years 9 months ago by probotix.
