- Thank you received: 358
Tower wrote:
What I don't understand is how it can be easier? You still have to implement the serial communication protocol, but this time on Arduino. And then you have to implement the digital input, the potentiometer input and transformation function for resistance-to-speed, error digital output for communication error and maybe more.bevins wrote: The easiest would be to energize a relay on spindle on and send that into an arduino.
Use the arduino with a pot to set speed and have arduino send out rs232 message depending on where the pot is set at or even a switch with preset speeds 10 for example. Surely you don't need that much rpm control, its just a drilling machine unless you want to use it for something else.
bevins wrote: Who cares if you have to go to Germany before heading back to France. You will get there either way.
Well, if you are on foot (you have to program all of it yourself), then I would care.
