- Thank you received: 338
Yeah, reading the docs tends to be fundamental when trying to solve problems. But I also started studying source codes (of Machinekit) first and it was infinite loop of Go to definitions and I have seen this 50 Go to definitions ago, what does this do again, so I get you.Mike_Eitel wrote: Hi tower. I completely agree with your way.
Have never read that doc. ;-( Will keep it in mind if I ever want to do something unusual.
Mike_Eitel wrote: It's really what I would call a starter. Unhazels all kind of real-time problems.
And I also agree to your not very positive judgment towards python. A language that does not force you to make declarations is bitting you sooner or later
Mike
rodw wrote: Yes, I'm much more comfortable with C, but with Python you can get done in 50-100 lines in Python can take over 1000 in C. Particularly if you start playing with API's out there on cloud based systems.
What I don't understand is how it can be easier? You still have to implement the serial communication protocol, but this time on Arduino. And then you have to implement the digital input, the potentiometer input and transformation function for resistance-to-speed, error digital output for communication error and maybe more.bevins wrote: The easiest would be to energize a relay on spindle on and send that into an arduino.
Use the arduino with a pot to set speed and have arduino send out rs232 message depending on where the pot is set at or even a switch with preset speeds 10 for example. Surely you don't need that much rpm control, its just a drilling machine unless you want to use it for something else.
bevins wrote: Who cares if you have to go to Germany before heading back to France. You will get there either way.
