Parallel Port -> 4-bit DAC driven monolothic chopper controller
- fungus
- Thank you received: 4
13 May 2019 14:14 #133654
by fungus
Parallel Port -> 4-bit DAC driven monolothic chopper controller was created by fungus
Pre-statement: I am sorry if this has been covered, and I am sure it's been thought of before.
I've been tinkering with the "Etch" example, and I really appreciate that it is available. What a great learning tool.
In taking apart a label printer, I ran across the TI LMD18245T: www.ti.com/lit/ds/symlink/lmd18245.pdf
It's a monolithic full H-bridge with integrated chopper controller, based on an internal DAC for current selection. This means that you can select a drive current based on 4 digital inputs.
It is my understanding in what I've read so far that stepper-based systems are greatly dependent on precise timing (as the motor's angular velocity is entirely dependent on every pulse position/length) whereas in a brushed DC application the motor has little/no cogging effect and therefore can tolerate less precise PWM timing.
That being said...
The CPU is still busy trying to generate the PWM signal, and the PWM is rather noisy (audible).
Would it offload anything from the CPU if one drove a chopper controller such as this one from a 4-bit value based off of PID out? I imagine this would be a component much like PWMGEN. It would consume 4 outputs + direction for each motor, which means that one parallel port could drive 2 motors, bring in 2 encoders, a shared limit switch and still have a couple outputs to spare.
I'm not trying to save money here, I'm just interested.
That being said...
- pl7i92
- Thank you received: 359
14 May 2019 01:45 #133700
by pl7i92
Replied by pl7i92 on topic Parallel Port -> 4-bit DAC driven monolothic chopper controller
this is the case as we Talk Hybrid
its a intirer controled Closed loop
with external step Direction signals
You need a 10times faster Cicuit then the PC signals to get a good result
it is not Nessusary if you tweek your Stepper System to a very good timing
as 100.000 (100k) ns time is for 60k steps per second SAFE step rate
most of here are investing in more Voltige and offcause more Torque steppers 8Nm then the speed
it is lower cost about 1/4 then servo
and it workes the same if you dont vneed the speed above 10meter/min
- fungus
15 May 2019 17:25 #133928
by fungus
Replied by fungus on topic Parallel Port -> 4-bit DAC driven monolothic chopper controller
Hi pl7i92!
I apologize, I didn't explain clearly where I was going with this. I found these in a stepper controller, but I am attempting to use them in a single full-bridge configuration with a brushed DC servo.
My google-foo fails me, but I believe the servo thread is less taxing on the CPU (it runs slower than the base thread). What I am curious about is whether it would be to some advantage (as far as the CPU is concerned) to hand off PWM generation for a DC servo (or power regulation in general) to a slave controller. In this case, it is parallel communication of 4 bits rather than an analog output (which would require a tuned low-pass filter or an external DAC).
The PWMGEN component currently has pins:
This would require (for example):and could probably reuseIt would consume a lot of outputs, but would tax the CPU less and get the motor's harmonics above human hearing range.
Again, this is just tinkering. I'm not trying to be a cheapskate
pwmgen.N.pwmpwmgen.N.dirThis would require (for example):
pwmgen.N.bit0pwmgen.N.bit1pwmgen.N.bit2pwmgen.N.bit3pwmgen.N.dirAgain, this is just tinkering. I'm not trying to be a cheapskate
- Thank you received: 7504
18 May 2019 19:15 #134229
Replied by tommylight on topic Parallel Port -> 4-bit DAC driven monolothic chopper controller
Am on a tablet that for some reason does not open the PDF.
PWM does not task the processor that much to cause it any issues, the noise you hear is from the low frequency of that PWM signal or from the chopper in the drive limiting the current to the motor.
PWM frequency can be set in Linuxcnc to pretty much anything within reason, but setting the chopping frequency might be harder or not possible at all for some drive IC's. That is always mentioned in the data sheet when there is a possibility of changing it.
The following user(s) said Thank You: fungus
- Thank you received: 2181
18 May 2019 20:58 #134233
Replied by cmorley on topic Parallel Port -> 4-bit DAC driven monolothic chopper controller
I believe you are right - sending a 4 bit output is easier on the CPU then making a PWM pulse because you can use the servo thread rather then a fast base thread.
Off loading high speed events is exactly what the Mesa/Pico cards do for linuxcnc.
Whether I works well in practice - will be interesting to know.
Chris M
Chris M
The following user(s) said Thank You: tommylight, fungus
19 May 2019 17:47 #134298
Replied by andypugh on topic Parallel Port -> 4-bit DAC driven monolothic chopper controller
I think this could be made to work, Take a PID scaled to give outputs from 0 to 16, pass the output through conv_float_u32 (or maybe ...s32, perhaps you can use the sign bit directly) and then in to
linuxcnc.org/docs/2.7/html/man/man9/bitslice.9.html
to make the output bits.
Actually, I wouldn't do that, I would write a custom HAL component to do it all in one lump, and with error checking etc.
- fungus
20 May 2019 20:12 #134420
by fungus
tommylight, thanks for the tip on being able to set the PWM frequency!
I ended up trying the following in the HAL file:Then noted the actual frequency in halscope and changed it to something reasonably lower. (6kHz sounds decent)
Yes, the chopping frequency on these chip-level drivers cannot always be changed. In the case of the L298N, it does not do any current regulation, nor does it have an internal chopper. The inputs are literally just hardware buffered before the inputs of the H-bridge. There seems to be a bit of debate concerning the optimum PWM frequency for the L298N, and I'm too lazy to do the math right now
setp pwmgen.0.pwm-freq 100000000setp pwmgen.1.pwm-freq 100000000Yes, the chopping frequency on these chip-level drivers cannot always be changed. In the case of the L298N, it does not do any current regulation, nor does it have an internal chopper. The inputs are literally just hardware buffered before the inputs of the H-bridge. There seems to be a bit of debate concerning the optimum PWM frequency for the L298N, and I'm too lazy to do the math right now
- fungus
20 May 2019 20:17 #134422
by fungus
andypugh, I'm going to try bitslice and report back. That would be an awesome workaround.
I'm returning to school this fall for computer science, and I'm really looking forward to diving deeper into LinuxCNC, make my own HAL components, etc. Currently I work for a company that's bringing me up to speed on FPGA architecture and PCB layout; I'm reading up on VHDL in my spare time. I can see this being my playground for a long time!
- fungus
20 May 2019 21:40 - 20 May 2019 22:20 #134429
by fungus
Added:
Current:Changed to:
Kept (to preserve Xdir & Ydir via pwmgen):
Added:
Kept:
Added:
Does the above sound correct? This does not prevent the calculation of PWM, as I need that component still for direction; it will, however, get things above human hearing AND control the current to the motor via resistor network.
(Pardon my understanding of net, pin and flow direction; I'm still getting a grip on how that is handled)
EDIT: There were a couple syntax issues, but it looks like this will work! I'm going to work over the circuit tomorrow and give it a go. I'll post the HAL, a video and the circuit diagram if it works (or if it fails catastrophically)
loadrt bitslice count=2 personality=4loadrt conv_float_u32 count=2addf bitslice.0 servo threadaddf bitslice.1 servo threadaddf conv-float-u32.0 servo-threadaddf conv-float-u32.1 servo-threadCurrent:
setp pid.0.maxoutput 1.0setp pid.1.maxoutput 1.0setp pid.0.maxoutput 16.0setp pid.1.maxoutput 16.0Kept (to preserve Xdir & Ydir via pwmgen):
net Xvel-cmd <= pid.0.outputnet Yvel-cmd <= pid.1.outputAdded:
net Xvel-cmd => conv-float-u32.0.innet Yvel-cmd => conv-float-u32.1.innet floatToBitsliceX conv-float-u32.0.out => bitslice.0.innet floatToBitsliceY conv-float-u32.1.out => bitslice.1.inKept:
net Xdir => parport.0.pin-0X-outnet Ydir => parport.0.pin-0X-outAdded:
net Xbit00 <= bitslice.0.out-00net Xbit01 <= bitslice.0.out-01net Xbit02 <= bitslice.0.out-02net Xbit03 <= bitslice.0.out-03net Ybit00 <= bitslice.1.out-00net Ybit01 <= bitslice.1.out-01net Ybit02 <= bitslice.1.out-02net Ybit03 <= bitslice.1.out-03net Xbit00 => parport.0.pin-0X-outnet Xbit01 => parport.0.pin-0X-outnet Xbit02 => parport.0.pin-0X-outnet Xbit03 => parport.0.pin-0X-outnet Ybit00 => parport.0.pin-0X-outnet Ybit01 => parport.0.pin-0X-outnet Ybit02 => parport.0.pin-0X-outnet Ybit03 => parport.0.pin-0X-outDoes the above sound correct? This does not prevent the calculation of PWM, as I need that component still for direction; it will, however, get things above human hearing AND control the current to the motor via resistor network.
Last edit: 20 May 2019 22:20 by fungus.
28 May 2019 13:52 #135186
Sorry, I have been tied up. How did this work out?
