Axis Y two motors gantry with separate switch home-offset
- Marco
20 Jul 2019 12:07 - 20 Jul 2019 12:08 #139980
by Marco
Axis Y two motors gantry with separate switch home-offset was created by Marco
i add gantry function in my configuration. Now i want make homing with separate home-offset for each motor of axis y. How can i do this ? i tried with KINS function but homing and motor velocity doesn't work anymore...
Last edit: 20 Jul 2019 12:08 by Marco.
- Thank you received: 7504
20 Jul 2019 12:36 #139986
Replied by tommylight on topic Axis Y two motors gantry with separate switch home-offset
The homing_sequence has to be -1 for both joints on the Y axis.
You can use -2 for Z axis to have it retract before moving X and Y axis.
Use the Home All for homing, not separate homing when starting the machine.
- Thank you received: 4154
20 Jul 2019 20:10 #140026
Replied by rodw on topic Axis Y two motors gantry with separate switch home-offset
Tommy and I are assuming you are using either V 2.8 or V 2.9
Say your Y axis gantry was 1.0mm out of square.
All you need to do is have HOME-OFFSET set to -3 on one side and -4 on the other side. The axis will be squared on homing.
This will not work in V 2.7 as it depends on features introduced in V 2.8.
21 Jul 2019 05:04 #140061
From the ini it looks like 2.7 or lower, there is no version entry. That will not work for gantry squaring.
21 Jul 2019 05:45 #140064
In that case, I would upgrade to V 2.8 by folllowing the instructions on the build bot buildbot.linuxcnc.org/
However, if its a plasma table, I'd go straight to V 2.9 to get the reverse run.
- pl7i92
- Thank you received: 359
21 Jul 2019 12:50 - 21 Jul 2019 12:50 #140093
by pl7i92
Replied by pl7i92 on topic Axis Y two motors gantry with separate switch home-offset
can somone who ownes a gantry setup like this plese post a full ini and hal on this
doesent matter what board
is the behavior diffferent on switch position max or min
Last edit: 21 Jul 2019 12:50 by pl7i92.
- Marco
24 Jul 2019 12:44 #140445
by Marco
Replied by Marco on topic Axis Y two motors gantry with separate switch home-offset
exactly, what should i do to upgrate my linuxcnc ? i dont understand what i have to do..
24 Jul 2019 14:17 #140459
Buildbot.linuxcnc.org
- BigJohnT
- Thank you received: 994
25 Jul 2019 05:51 - 25 Jul 2019 05:57 #140521
by BigJohnT
Why would you want reverse run for a plasma table?
JT
Replied by BigJohnT on topic Axis Y two motors gantry with separate switch home-offset
JT
Last edit: 25 Jul 2019 05:57 by BigJohnT.
25 Jul 2019 06:02 #140522
It is very helpful to have it for cases where the arc is lost during a cut or due to plasma overheating, you can just back off a bit and resume cutting.
Without it the procedure would be to run from line after choosing a straigh line somewhere before the arc was lost.
When cuting straight lines that is no issue at all, but when cutting art there are usually a lot of arcs involved.
Not a deal breaker in any way, just nice to have.
The following user(s) said Thank You: BigJohnT, rodw
Time to create page: 0.203 seconds
