emcoturn 120 / 220 tool turret hal outputs
- Erikcnc
23 Jul 2019 20:37 #140351
by Erikcnc
emcoturn 120 / 220 tool turret hal outputs was created by Erikcnc
Hi all,
From some one on youtube i got some files for getting the original emco 120 / 220 tool turret working.
its uses a 24v dc motor and the original encoder with 4 optos.
The motor is driven by a L298N motor module.
today i discovered that almost the same files where here on the forum. i used the comp file because i was missing that one.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...oolchanger_component
the only thing i struggle with is wiring the motor module.
In the hal file i got they go like
i am not fermilair with the gpio outputs.
i am using the mesa 7i76e as far i know it does not have gpio pins.
could some one help me out with this?
net forward_out pwmgen.0.pwm => hm2_5i25.0.gpio.005.outi am not fermilair with the gpio outputs.
##EMCOTC
loadrt pwmgen output_type=0,0
addf pwmgen.make-pulses servo-thread
setp pwmgen.0.pwm-freq 500.0
setp pwmgen.0.scale 100.0
setp pwmgen.0.offset 0.0
setp pwmgen.1.pwm-freq 500.0
setp pwmgen.1.scale 100.0
setp pwmgen.1.offset 0.0
loadrt emcochanger
addf emcochanger servo-thread
loadrt timedelay count=1
addf timedelay.0 servo-thread
# will wait 5 secs approx and turn motor off after reversing against stop
setp timedelay.0.on-delay 2
net tool-change iocontrol.0.tool-change => emcochanger.toolchange
net tool-changed iocontrol.0.tool-changed <= emcochanger.toolchanged
net tool-number iocontrol.0.tool-prep-number => emcochanger.toolnumber
net tool-oldnumber iocontrol.0.tool-number => emcochanger.currenttoolnumber
net sig1 emcochanger.opto1 <= hm2_5i25.0.7i76.0.0.input-16
net sig2 emcochanger.opto2 <= hm2_5i25.0.7i76.0.0.input-17
net sig3 emcochanger.opto3 <= hm2_5i25.0.7i76.0.0.input-18
net sig4 emcochanger.opto4 <= hm2_5i25.0.7i76.0.0.input-19
setp hm2_5i25.0.gpio.004.is_output true
setp hm2_5i25.0.gpio.005.is_output true
#net sig-forward emcochanger.forward => hm2_5i25.0.gpio.005.out
#net sig-backward emcochanger.backward => hm2_5i25.0.gpio.004.out
setp pwmgen.0.enable true
setp pwmgen.1.enable true
net forward_motor pwmgen.0.value <= emcochanger.forwardpwm
net backward_motor pwmgen.1.value <= emcochanger.backwardpwm
net backward_out pwmgen.1.pwm => hm2_5i25.0.gpio.004.out
net delaystart timedelay.0.in <= emcochanger.delaystart
net delaydone timedelay.0.out => emcochanger.delaydone
##EMCOTCPlease Log in or Create an account to join the conversation.
- BigJohnT
- Thank you received: 994
24 Jul 2019 12:03 #140423
by BigJohnT
Replied by BigJohnT on topic emcoturn 120 / 220 tool turret hal outputs
The 7i76e output pins have names like hm2_7i76e.0.7i76.0.0.output-00. Run an Axis config and show hal configuration will show all the pin names.
JT
JT
The following user(s) said Thank You: Erikcnc
- Erikcnc
24 Jul 2019 12:50 - 24 Jul 2019 12:51 #140426
by Erikcnc
Thanks JT.
I am familair with these DO pins.
As far i saw on the video on youtube, the IN1 and IN2 of the L298n board are conected to 3rd row for a step/dir config.
The L298n needs 5v inputs, instead of the 24v thats coming out of the Digital outputs pins...I am a little bit concern that i am coing to blow thins up with that.
So i tried the hal file i get from the forum.
I set this up for my mesa 7i76e, just to test it out if its working.
I changed
In to:
Now i am getting error
hal:62: pin ' pwmgen.0.enable' does not exist.
Replied by Erikcnc on topic emcoturn 120 / 220 tool turret hal outputs
JT
Thanks JT.
###############Toolchanger#########################
loadrt emcochanger
loadrt timedelay count=2
# will wait 2 secs approx and turn motor off after reversing against stop
setp timedelay.0.on-delay 0.8
#Toolchanger delay time before reverse lock
addf timedelay.1 servo-thread
setp timedelay.1.on-delay 0.2
net sig1 emcochanger.opto1 <= hm2_7i76e.0.7i76.0.0.input-21
net sig2 emcochanger.opto2 <= hm2_7i76e.0.7i76.0.0.input-22
net sig3 emcochanger.opto3 <= hm2_7i76e.0.7i76.0.0.input-23
net sig4 emcochanger.opto4 <= hm2_7i76e.0.7i76.0.0.input-24
#direction signal for toolchanger
net sig-forward emcochanger.forward =>hm2_7i76e.0.7i76.0.0.output-01
#run signal for toolchanger
net x-enable => pwmgen.0.enable
net pwmgen_value pwmgen.0.value <= emcochanger.setpwm
net pwmgen_out pwmgen.0.pwm => hm2_7i76e.0.7i76.0.0.output-02
setp hm2_7i76e.0.7i76.0.0.output-00.invert 1
setp hm2_7i76e.0.7i76.0.0.output-01.invert 1
net xhomed axis.0.homed => emcochanger.ishomedX
net zhomed axis.2.homed => emcochanger.ishomedZ
net delaystart1 timedelay.1.in <= emcochanger.delaystart1
net delaydone1 timedelay.1.out => emcochanger.delaydone1
# if the delay is too long in switching relays for forward and reverse
# setp emcochanger.times 300
# for instance will make it shorter, default is 500 - about 1-2 secs on my systemI set this up for my mesa 7i76e, just to test it out if its working.
I changed
net sig-forward emcochanger.forward => parport.0.pin-16-out
net pwmgen_out pwmgen.0.pwm => parport.0.pin-17-out
setp parport.0.pin-14-out-invert 1
setp parport.0.pin-16-out-invert 1In to:
setp hm2_7i76e.0.7i76.0.0.output-01.invert 1Now i am getting error
Last edit: 24 Jul 2019 12:51 by Erikcnc.
- Thank you received: 7480
24 Jul 2019 13:06 #140428
Replied by tommylight on topic emcoturn 120 / 220 tool turret hal outputs
L298 does not have current limiting so attaching it directly to step/dir pins will most probably cause it to fail as soon as a change in direction is issued.
Consult PCW about having a PWM output on step/dir pins.
- Thank you received: 5326
24 Jul 2019 14:41 - 24 Jul 2019 14:42 #140432
Replied by PCW on topic emcoturn 120 / 220 tool turret hal outputs
Yes, if you want 5V PWM pins, you should use a hardware PWMGen on the step/dir pins
or on the 7I76E's expansion port , perhaps with a low cost 5V breakout board to buffer/protect the 7I76E pins
Last edit: 24 Jul 2019 14:42 by PCW.
- Erikcnc
24 Jul 2019 14:56 - 24 Jul 2019 15:23 #140434
by Erikcnc
Thanks! that is what i was thinking of. Only can't figure out what line to use?
What are the pins being called to make this work?
Last edit: 24 Jul 2019 15:23 by Erikcnc.
- Mike_Eitel
- Thank you received: 183
24 Jul 2019 16:35 #140439
by Mike_Eitel
Replied by Mike_Eitel on topic emcoturn 120 / 220 tool turret hal outputs
LM298 chip has sense resistors pins that alow to measure and limit motor current. The logic input pins are ttl level.
Togeather with LM297 it allows to make your own "Stepper driver".
But that gives not a fun solution... Been there years agoo ;-(
Mike
Mike
24 Jul 2019 16:47 #140440
First you would need firmware that has a a hardware PWM generator,
Then you would need to setup that hardware PWM generator
You would also need to be careful about the startup state of the PWM
pins
What interface pins do you need?
pins
- Erikcnc
24 Jul 2019 21:35 - 24 Jul 2019 21:40 #140477
by Erikcnc
hmm. didn`t expect to do everything on the firmware with chance to ruining it.
i prefer to use the stepgen outputs.
Actually i prefer the best solution. I thought this whats a easy solution in stead of the toolerator3000 option.
if you watch this, you see at 2:20 two wires that goes from the l298n module to the mesa .
His hal file is different then i got from theisforum.
pins
##EMCOTC
loadrt emcochanger
##EMCOTC
Last edit: 24 Jul 2019 21:40 by Erikcnc.
24 Jul 2019 22:07 - 24 Jul 2019 22:38 #140479
You cannot do 500 Hz PWM with the 7I76E field outputs so a firmware change is required
There is not any real risk of bricking the 7i76E unless you write an incorrect file to both EEPROMS
If you only need 2 PWM signals and you don't need all 5 stepgens, the easiest way to get these signals is
to "steal" the last (04) stepgen pins with firmware that puts a PWM generator on these pins
It sounds like you would want a single PWM gen used in up/down mode
(this puts the PWM value on one pin for positive numbers and the other pin for negative numbers)
Note that the 7i76e_7i76x1pD.bit firmware has this configuration (last stepgen replaced with a PWMgen)
Last edit: 24 Jul 2019 22:38 by PCW.
Time to create page: 2.701 seconds
