Hal Standalone. some trouble..
7 years 1 month ago #145563 by dab77
Do you have any suggestion on how to make stepgen decelerate if, in position mode, I have to stop in the middle of a movement?
7 years 1 month ago #145566 by cmorley
Would simple_tp be helpful?
linuxcnc.org/docs/2.8/html/man/man9/simple_tp.9.html
It's a single joint jogging component - same as linuxcnc uses.
7 years 1 month ago #145567 by cmorley
You could also look at the axis test used in stepconf.
Though I think it stops immediately if you stop in the middle of a jog.
Chris
Time to create page: 0.266 seconds
