MPG with axis and scale selector for 7i76e Lathe
- Erikcnc
22 Sep 2019 14:02 - 22 Sep 2019 14:08 #145883
by Erikcnc
MPG with axis and scale selector for 7i76e Lathe was created by Erikcnc
After finishing the feed override knob issue on my lathe, its now time to get the mpg to work.
So, the MPG Example here, does not count for the mesa 7i76e.
I it alls set in Mode 2, that's also needed for the feedrate override knob if using the analog input.
More here.
Feed-override
I use:
-one MPG wheel
-two selector switches for selecting axis (set for 2 outputs) and other for the scale.(set for 3 outputs) (1mm, 0.1mm and 0.01mm)
mpg is connected to hm2_7i76e.0.7i76.0.0.enc0.count ( 17 and 18 )
who can help me out with this?
maybe good thing to know, machine got servo motors.
should this be use full?
mpg from KCJ
More here.
Feed-override
I use:
-one MPG wheel
mpg from KCJ
Last edit: 22 Sep 2019 14:08 by Erikcnc.
- Thank you received: 7504
22 Sep 2019 16:58 #145894
Replied by tommylight on topic MPG with axis and scale selector for 7i76e Lathe
That config from KCJ also uses the mpg.comp, so you will also need to download that and compile.
- pl7i92
- Thank you received: 359
23 Sep 2019 02:10 #145926
by pl7i92
Replied by pl7i92 on topic MPG with axis and scale selector for 7i76e Lathe
as you are now in the way to get a PRO Linuxcnc you shouidt considder to use your own COMP
as you will be faced to mix up with AND -Or you can also use classic ladder to get the mpg to full work
for standard Hal operation use the Encoder comp
linuxcnc.org/docs/html/man/man9/
BEST is also to get a KEY_switch for manuell and Auto mode maybe also MDI but i never used this
its a bit hard to work at the start but you will fast overcome it
- Thank you received: 4154
23 Sep 2019 04:55 - 23 Sep 2019 04:56 #145941
Replied by rodw on topic MPG with axis and scale selector for 7i76e Lathe
There is a complete worked example of how to use 7i76e MPG's in my Spaceship Plasma Build thread that starts here
forum.linuxcnc.org/show-your-stuff/32029...build?start=20#85279
Last edit: 23 Sep 2019 04:56 by rodw.
Time to create page: 0.138 seconds
