Thank you MicI did not know of this tool
I will installl and try
Thanks TomP
EDIT:no joy , could not start server, webpack complains 'overlay' is not a valid option
Editor-master$ sudo npm start
[sudo] password for tomp:
> linuxcnc_halbuilder@0.0.1 start
> ./node_modules/.bin/webpack serve --open[webpack-cli]
Invalid options object.
Dev Server has been initialized using an options object that does not match the API schema.
- options has an unknown property 'overlay'.
These properties are valid: object { allowedHosts?, bonjour?, client?, compress?, devMiddleware?, headers?,
historyApiFallback?, host?, hot?, http2?, https?, ipc?, liveReload?, magicHtml?, onAfterSetupMiddleware?, onBeforeSetupMiddleware?, onListening?, open?, port?, proxy?, server?, setupExitSignals?, static?,
watchFiles?, webSocketServer? }
the log file is attached
(lots of unresolved deps)
Linux dbn9sda1 4.9.0-16-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.272-2 (2021-07-19) x86_64 GNU/Linux
thx
tomp
