Graphing a HAL configuration
16 Nov 2019 11:52 #150485 by kentavv
Graphing a HAL configuration was created by kentavv
Is there a nice way to graph HAL configurations? The HAL Configuration dialog in Axis is informative, but I thought graphing might be useful. I'd like a way to better understand and review my own HAL files but perhaps a different view would help others modify theirs. If a graphing tool not exists, I'd be glad to make an attempt to write one.
16 Nov 2019 12:43 #150490 by tommylight
Replied by tommylight on topic Graphing a HAL configuration
Have a look here, user Grotius did just that.
The following user(s) said Thank You: kentavv
16 Nov 2019 15:50 #150495 by kentavv
Replied by kentavv on topic Graphing a HAL configuration
Is the following link to the right program? Thank you, I'll check it.
forum.linuxcnc.org/plasma-laser/34978-th...w-to?start=40#115472
16 Nov 2019 16:26 #150496 by tommylight
Yes.
17 Nov 2019 02:45 #150509 by pl7i92
Replied by pl7i92 on topic Graphing a HAL configuration
isent just the hal_show on pins a good as it showes al connected pins to eatch other
a graph may be good for peopel with background in programming
but the normal metall worker with non pc background will be upset on all the lines
18 Nov 2019 07:56 #150581 by andypugh
Replied by andypugh on topic Graphing a HAL configuration
The following user(s) said Thank You: tjtr33, kentavv
06 Nov 2021 08:23 - 07 Nov 2021 18:12 #225499 by tjtr33
Replied by tjtr33 on topic Graphing a HAL configuration
I have always been fascinated by graphs and maps
Here's another tool for Hal visualization
Its a graph editor,  it is very preliminary
Its called Nodz and is at
github.com/LeGoffLoic/Nodz/tree/master
I modified it to:
pan zoom scroll and aded net names to the beziers
I changed some transparencies to allow the nets to be visible thru the comps
( rather than code the beziers to avoid comps )
I hard coded a few comps into the demo
I enabled save and load
There is a lot to be done to make this as useful as RockHopper and HalPyGraph
but it looks promising
I am not versed in Python, so the aliasing and choosing the
correct flavours of QtGui QtCore abd QtWidgets was hard-won.
The next challenge for me is to make unique names for each 'plug' (net names)
( another dict to learn, a plug is a source pin sorta )
So, many simple hacks have been done but the
parse hal, output editable graph, save graph and new hal
is a long way off.
I invite any wanting to, to get my source. ( its just 4 text files so far)
thanks
Tomp 06nov2021 20:16 Thailand
Last edit: 07 Nov 2021 18:12 by andypugh. Reason: typos
The following user(s) said Thank You: nkp, tommylight, vmihalca
06 Nov 2021 08:37 #225500 by tommylight
Sweet! :)
Thank you.
06 Nov 2021 16:58 #225532 by cmorley
Replied by cmorley on topic Graphing a HAL configuration
interesting - it could be embedded into one on the qtvcp screens.
I would suggest setting it up similar to halshow where you can pick a component for a list then it will visualize the connections related to that component.
Showing the whole configuration in one visualisation seems like it would be awkward.
07 Nov 2021 01:06 - 07 Nov 2021 01:09 #225547 by tjtr33
   I have not thought about embedding it, possible though.
   It's meant to help explain  text based netlists
  Thats possible, a palette could show comps,
  but again the intent is to show hal relationships rather than indvidual comp pin/params
  But users can do as they wish ( i did similar in geda long ago )
  Agreed, a basic problem in visualization is seeing the part you are interested in  and how that relatess to the whole.
   I think thats where the user can re-organize/subdivide logical groups  that fit on a 'page' ( old Forth concept )
   yet still scroll to the sorurces or destinations of that logical group. And to zoom out to see how the grouping
   relates to the whole.  I think it is an 'explainer'.
  There's a great video by Lyft Architects about how complex diagrams can be viewd /edited
  Its on Vimeo, but you dont really have to join to see it
     vimeo.com/72447811
  thats the bleeding edge bladerunner extreme ;-) tomp
Last edit: 07 Nov 2021 01:09 by tjtr33. Reason: typos
Time to create page: 0.092 seconds
