Graphing a HAL configuration
- kentavv
16 Nov 2019 17:52 #150485
by kentavv
Graphing a HAL configuration was created by kentavv
Is there a nice way to graph HAL configurations? The HAL Configuration dialog in Axis is informative, but I thought graphing might be useful. I'd like a way to better understand and review my own HAL files but perhaps a different view would help others modify theirs. If a graphing tool not exists, I'd be glad to make an attempt to write one.
- Online
- Thank you received: 7488
16 Nov 2019 18:43 #150490
Replied by tommylight on topic Graphing a HAL configuration
Have a look here, user Grotius did just that.
The following user(s) said Thank You: kentavv
- kentavv
16 Nov 2019 21:50 #150495
by kentavv
Replied by kentavv on topic Graphing a HAL configuration
Is the following link to the right program? Thank you, I'll check it.
forum.linuxcnc.org/plasma-laser/34978-th...w-to?start=40#115472
- Online
16 Nov 2019 22:26 #150496
Yes.
- pl7i92
- Thank you received: 358
17 Nov 2019 08:45 #150509
by pl7i92
Replied by pl7i92 on topic Graphing a HAL configuration
isent just the hal_show on pins a good as it showes al connected pins to eatch other
a graph may be good for peopel with background in programming
but the normal metall worker with non pc background will be upset on all the lines
18 Nov 2019 13:56 #150581
Replied by andypugh on topic Graphing a HAL configuration
The following user(s) said Thank You: tjtr33, kentavv
- tjtr33
- Thank you received: 54
06 Nov 2021 13:23 - 08 Nov 2021 00:12 #225499
by tjtr33
Replied by tjtr33 on topic Graphing a HAL configuration
I have always been fascinated by graphs and maps
Here's another tool for Hal visualization
Its a graph editor, it is very preliminary
Its called Nodz and is at
github.com/LeGoffLoic/Nodz/tree/master
I modified it to:
pan zoom scroll and aded net names to the beziers
I changed some transparencies to allow the nets to be visible thru the comps
( rather than code the beziers to avoid comps )
I hard coded a few comps into the demo
I enabled save and load
There is a lot to be done to make this as useful as RockHopper and HalPyGraph
but it looks promising
I am not versed in Python, so the aliasing and choosing the
correct flavours of QtGui QtCore abd QtWidgets was hard-won.
The next challenge for me is to make unique names for each 'plug' (net names)
( another dict to learn, a plug is a source pin sorta )
So, many simple hacks have been done but the
parse hal, output editable graph, save graph and new hal
is a long way off.
I invite any wanting to, to get my source. ( its just 4 text files so far)
thanks
Tomp 06nov2021 20:16 Thailand
I modified it to:
is a long way off.
thanks
Last edit: 08 Nov 2021 00:12 by andypugh. Reason: typos
The following user(s) said Thank You: nkp, tommylight, vmihalca
- Online
06 Nov 2021 13:37 #225500
Sweet!
Thank you.
Thank you.
- Thank you received: 2181
06 Nov 2021 21:58 #225532
Replied by cmorley on topic Graphing a HAL configuration
interesting - it could be embedded into one on the qtvcp screens.
I would suggest setting it up similar to halshow where you can pick a component for a list then it will visualize the connections related to that component.
Showing the whole configuration in one visualisation seems like it would be awkward.
- tjtr33
07 Nov 2021 06:06 - 07 Nov 2021 06:09 #225547
by tjtr33
I have not thought about embedding it, possible though.
It's meant to help explain text based netlists
Thats possible, a palette could show comps,
but again the intent is to show hal relationships rather than indvidual comp pin/params
But users can do as they wish ( i did similar in geda long ago )
Agreed, a basic problem in visualization is seeing the part you are interested in and how that relatess to the whole.
I think thats where the user can re-organize/subdivide logical groups that fit on a 'page' ( old Forth concept )
yet still scroll to the sorurces or destinations of that logical group. And to zoom out to see how the grouping
relates to the whole. I think it is an 'explainer'.
There's a great video by Lyft Architects about how complex diagrams can be viewd /edited
Its on Vimeo, but you dont really have to join to see it
vimeo.com/72447811
thats the bleeding edge bladerunner extreme
tomp
vimeo.com/72447811
Last edit: 07 Nov 2021 06:09 by tjtr33. Reason: typos
