G33.1 - no position reset when index detects
6 years 9 months ago #153999 by Cynas
I will try to build such a system
Thank you
6 years 9 months ago #154018 by Cynas
I made a simple circuit with an optocoupler.
On the table works, when there will be a moment of free time, check it on the machine.
Thank you again
6 years 9 months ago #154312 by Cynas
One picture expresses more than 1000 words :)
6 years 9 months ago #154326 by Clive S
Very nice.
Would you mind posting your config files.
6 years 9 months ago #154327 by Cynas
#******************* # SPINDLE S #******************* setp pid.s.Pgain [SPINDLE_9]P setp pid.s.Igain [SPINDLE_9]I setp pid.s.Dgain [SPINDLE_9]D setp pid.s.bias [SPINDLE_9]BIAS setp pid.s.FF0 [SPINDLE_9]FF0 setp pid.s.FF1 [SPINDLE_9]FF1 setp pid.s.FF2 [SPINDLE_9]FF2 setp pid.s.deadband [SPINDLE_9]DEADBAND setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT setp pid.s.error-previous-target true net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm-abs => pid.s.command net spindle-vel-fb-rpm-abs => pid.s.feedback net spindle-output <= pid.s.output # ---digital potentionmeter output signals/setup--- setp hm2_7i76e.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT setp hm2_7i76e.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT setp hm2_7i76e.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE net spindle-output => hm2_7i76e.0.7i76.0.0.spinout #net spindle-enable => hm2_7i76e.0.7i76.0.0.spinena net spindle-enable => or2.0.in0 net spindle-enable-oriented => or2.0.in1 net spindle-enable-or2.0 or2.0.out => timedelay.1.in net opoznienie-spindle-enable timedelay.1.out => hm2_7i76e.0.7i76.0.0.spinena net spindle-ccw => hm2_7i76e.0.7i76.0.0.spindir # ---Encoder feedback signals/setup--- setp hm2_7i76e.0.encoder.00.counter-mode 1 setp hm2_7i76e.0.encoder.00.filter 1 setp hm2_7i76e.0.encoder.00.index-invert 0 setp hm2_7i76e.0.encoder.00.index-mask 0 setp hm2_7i76e.0.encoder.00.index-mask-invert 0 setp hm2_7i76e.0.encoder.00.scale [SPINDLE_9]ENCODER_SCALE net spindle-revs <= hm2_7i76e.0.encoder.00.position net spindle-vel-fb-rps <= hm2_7i76e.0.encoder.00.velocity net spindle-index-enable <=> hm2_7i76e.0.encoder.00.index-enable # ---setup spindle control signals--- net spindle-speed-cmd-rps <= motion.spindle-speed-cmd-rps net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs net spindle-vel-cmd-rpm <= motion.spindle-speed-out net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs net spindle-enable <= motion.spindle-on net spindle-cw <= motion.spindle-forward net spindle-ccw <= motion.spindle-reverse net spindle-brake <= motion.spindle-brake net spindle-revs => motion.spindle-revs net spindle-at-speed => motion.spindle-at-speed net spindle-vel-fb-rps => motion.spindle-speed-in net spindle-index-enable <=> motion.spindle-index-enable net spindle-orient <= motion.spindle-orient net spindle-is-oriented => motion.spindle-is-oriented net spindle-locked <= motion.spindle-locked # ---Setup spindle at speed signals--- sets spindle-at-speed true
Time to create page: 0.277 seconds
