Want to run C2000 Delta with Ethercat card
5 years 10 months ago - 5 years 10 months ago #190895 by Mduran
Hi @snujcnc,
did you manage to get delta to work with ethercat card?
Last edit: 5 years 10 months ago by Mduran.
5 years 10 months ago #190904 by chimeno
Hello @Mike Duran
If you have the physical device I can try to help you.
Greeting
Chimeno
5 years 10 months ago #192456 by snujcnc
Sorry for late reply ....
i have phisycal device with me ....
please tell me next step ....
5 years 10 months ago #192457 by snujcnc
5 years 10 months ago - 5 years 10 months ago #192465 by chimeno
Hello @snujcnc,
Have TWINCAT3 to configure and test it to work??
Do you have a manual??
You have linuxcnc-ethercat installed??
you can scan the device with the command
sudo ethercat pdos
to get that the PDO starts with the device, then it would try to create the ethercat .xml configuration file with the generic mode
Greeting
Chimeno
Last edit: 5 years 10 months ago by chimeno. Reason: Edit
3 years 8 months ago #265595 by diegojulio
Hello Chimeno, I want to know if you can help me to configure the generic XML file for Delta C2000 plus VFD with ethercat card CMC-EC01?
I can see the drive with ethercat slaves, but when I run the ethercat slaves pdos, the slave does not appear. Thanks in advance
