spindle encoder help
- Dinuka_Shehan
- Thank you received: 26
08 Mar 2020 01:54 #159446
by Dinuka_Shehan
spindle encoder help was created by Dinuka_Shehan
I bought omron 100ppr quadrature encoder to connect my bob.
connect pin 10 and 11 as phase A and index.
stepconfig select those pin as mentioned but not spindle speed not working,
what is missing?
what is missing?
- BeagleBrainz
- Visitor
08 Mar 2020 03:14 #159449
by BeagleBrainz
Replied by BeagleBrainz on topic spindle encoder help
Mate don't start new threads for basically the same issue, otherwise it get confusing. Keep it all to one thread.
Also information about how you connected it up......ie: Power & Gnd and your hal & ini files.
Maybe even a link to the product datasheet. The more info the better the help. It's tiring to have to pull information from people.
- Dinuka_Shehan
08 Mar 2020 03:21 - 08 Mar 2020 03:33 #159450
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic spindle encoder help
# set the HAL encoder to 100 pulses per revolution.
setp encoder.3.position-scale 100
This code is the error shows whrn click the linuxcnc
Last edit: 08 Mar 2020 03:33 by Dinuka_Shehan.
- Dinuka_Shehan
08 Mar 2020 03:27 #159451
by Dinuka_Shehan
encoder
- Dinuka_Shehan
08 Mar 2020 03:32 #159452
by Dinuka_Shehan
wiring
- Thank you received: 5328
08 Mar 2020 03:54 - 08 Mar 2020 03:56 #159455
Replied by PCW on topic spindle encoder help
A couple of things:
1. if you are using both A and B lines from the encoder (quadrature) you will have 400 counts
per turn so the scale should be 400 not 100
EDIT I see you are using only A and index so 100 is correct for counter mode
2. why do you have encoder 3 instead of 0?
3. People can be of more help if you post your hal/ini files and any error messages
you recieve
you recieve
Last edit: 08 Mar 2020 03:56 by PCW.
- Dinuka_Shehan
08 Mar 2020 08:08 #159457
by Dinuka_Shehan
1.i follow the linux cnc spindle configuration documentation.A couple of things:
instead of 0?
any error messages
you recieve
- Dinuka_Shehan
08 Mar 2020 08:13 #159458
by Dinuka_Shehan
i am using linux cnc wheezey 2.7.
Can not change the time and so cannot be connected to internet.
I try to copy config file to usb but it also cannot done.
So i will copy text and send you as a text file.
- Dinuka_Shehan
08 Mar 2020 08:17 #159459
by Dinuka_Shehan
I try this.
Can you please explain how to connect pin 14 as spindle on and pin 17 as spindle cw to hal and bob to motor.
I am currently using three phase motor with contactor.not have vfd.
A couple of things:
I try this.
- Dinuka_Shehan
08 Mar 2020 10:39 #159463
by Dinuka_Shehan
hal
Time to create page: 0.173 seconds
