spindle encoder help
08 Mar 2020 09:52 #159471 by PCW
Replied by PCW on topic spindle encoder help
Right, so as I mentioned the encoder number is wrong.
(you dont need 3 encoders and if you create 3 encoders
you will still not have encoder number 3 ( just encoders 0,1,2 )
In your custom.hal, replace
loadrt encoder num_chan=3
with
loadrt encoder
The replace all instances of "encoder.3" with "encoder.0"
and you should be a lot closer.
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
08 Mar 2020 15:16 - 08 Mar 2020 21:49 #159506 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic spindle encoder help
Thank you PCW.
I tried that trick.
but no digits displa in the spindle speed dialogue but spindle at speed becomes green to red.
without inputting encoder to stepconf spindle speed dialogue in axis gui becomes 0 to 1 when i spndle CW
Last edit: 08 Mar 2020 21:49 by Dinuka_Shehan.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
08 Mar 2020 15:34 - 08 Mar 2020 15:46 #159508 by Dinuka_Shehan
Spindle Enable
If you need a spindle enable signal, link your output pin to motion.spindle-on. To link these pins to a parallel port pin put something like the following in your .hal file, making sure you pick the pin that is connected to your control device.
net spindle-enable motion.spindle-on => parport.0.pin-14-out
4. Spindle Direction
If you have direction control of your spindle the HAL pins motion.spindle-forward and motion.spindle-reverse are controlled by M3 and M4. Spindle speed Sn must be set to a positive non-zero value for M3/M4 to turn on spindle motion.
To link these pins to a parallel port pin, put something like the following in your .hal file making sure you pick the pin that is connected to your control
device.
net spindle-fwd motion.spindle-forward => parport.0.pin-16-out
net spindle-rev motion.spindle-reverse => parport.0.pin-17-out
1) Linux cnc spindle configuration documentation says pin 14 as spindle enable to hal.
If i add net spindle-enable motion.spindle-on => parport.0.pin-14-out
What should be the hardware configuration.
2) As well as i am using a 5 axis chinese breakout board.use pin 17 as spindle cw.i hook up wire like this.
Pin 17 > bob relay normally open > auxiliary 5v coil (it connect to 230V contactor coil)
> it will run the 3 phase motor.
How can i run spindle ccw and i want to run both directions by on off by bob instead do it manually.
Any suggestions?
By
Shehan
Last edit: 08 Mar 2020 15:46 by Dinuka_Shehan.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
08 Mar 2020 21:51 #159556 by Dinuka_Shehan
something wrong i have done?
can't i check my encoder if it working or not.
s their any solution?
08 Mar 2020 22:01 - 08 Mar 2020 22:01 #159557 by PCW
Read the encoder position with halmeter
The encoder position (encoder.0.position)
should increase by 1.000 every spindle rotation
if your scaling (and wiring etc) is correct.
Last edit: 08 Mar 2020 22:01 by PCW.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
08 Mar 2020 22:55 #159560 by Dinuka_Shehan
always 0 (encoder.0.position) when it rotation in hal meter
i connect pins like this
pin 10 to phase A
pin 11 to phase B
pin 12 to index
pc 5V to encoder 5V to 12VDC
pc gnd to encoder 0V (common)
GND(sheild) not connected
08 Mar 2020 23:23 #159563 by PCW
How are A and B connected? If you are using a standard 5 AXIS type
BOB, the BOB inputs are not 5V compatible AFAIK
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
08 Mar 2020 23:50 #159565 by Dinuka_Shehan
i connect pin 10 to phase A
And pin 11 to phase B.
Is my bob not compatible for encoder input or bob 5V is not enough for encoder.
Or both matters for this probelem.
Nexr thing is 0V and gnd wires should connect together?
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
08 Mar 2020 23:53 #159566 by Dinuka_Shehan
yes pin 10 and gnd have 12V voltage.
Bob is 5 axis chinese breakout board.$5 one when i bought from ebay.
Time to create page: 0.250 seconds
