xhc-hb04 .Why can't I make it work?
- RobotMatic
- Thank you received: 25
20 Mar 2020 22:55 - 20 Mar 2020 23:25 #160956
by RobotMatic
xhc-hb04 .Why can't I make it work? was created by RobotMatic
Last edit: 20 Mar 2020 23:25 by RobotMatic. Reason: add information
- bbsr_5a
- Thank you received: 106
21 Mar 2020 12:01 #160979
by bbsr_5a
Replied by bbsr_5a on topic xhc-hb04 .Why can't I make it work?
hi it is the old version or the new one
did you follow the Wikipedia to get it set up
you did not post hal and ini
is all settings inside the POSTGUI
i added the complete machine i got
The following user(s) said Thank You: RobotMatic
- RobotMatic
21 Mar 2020 13:59 #160986
by RobotMatic
Replied by RobotMatic on topic xhc-hb04 .Why can't I make it work?
Hi. I am using 2.7.15. I pass you the files I made.Thanks for trying to help me, I am going to study your files.
- RobotMatic
21 Mar 2020 15:20 - 21 Mar 2020 15:21 #160987
by RobotMatic
AGAIN FOLLOWED THE WIKI INSTRUCTIONS AND ACHIEVED A DIFFERENT RESULT. I'LL SHOW IT TO YOU
"Using xhc-hb04-layout*.ini files to modify your own .ini "
I AM VERY DISORIENTED
Last edit: 21 Mar 2020 15:21 by RobotMatic.
- bbsr_5a
21 Mar 2020 15:58 #160989
by bbsr_5a
there is no way this will work the way you set it up
the USB component needs to be loded inside a postgui for correct function
also as it is a wifi system refering to the INI the component seams to be coustom made
your setup order of the HAL is wrong
mashine FIRST
then the halui
then the coustom
then also coustom the hb04
at last the tcl settings
what are gives you given if you start the mashine i gave you
mashine FIRST
then the halui
then the coustom
- RobotMatic
21 Mar 2020 19:46 #161022
by RobotMatic
I cannot understand your file, it is very modified, I send you a corrected copy with your explanation, but it gives me an error that cannot find a file. I am doing the simplest configuration and then work on it. Thank you very much !!!!!
It seems to start !!! , but no!!
- BeagleBrainz
- Visitor
21 Mar 2020 21:46 #161030
by BeagleBrainz
Replied by BeagleBrainz on topic xhc-hb04 .Why can't I make it work?
Whilst I’ve been watching this thread I haven’t commented, but one thing I have noted is that the error messages have clearly stated things like no servo thread can’t find file and the like. Have you addressed these issues ? Or have you just been concerned that the pendant isn’t operating ?
Have you been able to get a working config, one that works without trying to get the pendant working ?
If it was me I’d concentrate on having a configuration that is able to operate my machine and run gcode. Make a backup of that and then attempt to get the pendant going. Theoretically any issues should be in the file pertaining to the pendant not the main machine.
The error messages usually give a good idea of what the issues are eg pins not existing ( generally a typo or something you’ve forgotten to add ), unable to find a file once again a typo or the file not in the location expected. These are actually examples of what I’ve seen in your error messages.
Don’t be freaked out by the messages, read each line and when you come across something address that issue. Bit by bit is a good way. Be cool and relaxed.......walk away from it for a day, if you can, do something else and then give it another go. You’ll be fresh and relaxed. It’s something that’s worked for myself in different fields.
- RobotMatic
21 Mar 2020 22:44 #161034
by RobotMatic
I am using the whb04 wifi mpg without problems when I run the simulator that is integrated in linuxcnc. I try to make a new configuration following the steps and it doesn't work for me, I have ordered the order of execution of the hal and tcl files and I got the last error message. I can not see because of my lack of experience what is the error .. I will continue !! thank you for your response !!
- BeagleBrainz
- Visitor
21 Mar 2020 23:10 #161036
by BeagleBrainz
You have a message:
CANNOT FIND FILE FOR:monitor_xhc-hb-104.tcl
Like I said the error log gives a pretty good idea of the issue. Is that file name correct ? Do you have that file ?
Then Linuxcnc is shutting down. That is the issue. sort that issue out.
- dgarrett
- Thank you received: 297
21 Mar 2020 23:13 #161037
by dgarrett
The monitor_xhc-hb04.tcl is *not* a HALFILE,
it belongs in the [APPLICATIONS] section.
(And the naming is monitor-xhc-hb04
*not* monitor_xhc-hb04.tcl).
Example:
Ref (README): github.com/LinuxCNC/linuxcnc/blob/2.7/co...xhc-hb04/README#L141
Ref (Example sim config): github.com/LinuxCNC/linuxcnc/blob/2.7/co...hb04-layout2.ini#L43
Replied by dgarrett on topic xhc-hb04 .Why can't I make it work?
An observation: your inifile (fresa-HB04_2020-03-21.ini) excerpt:CANNOT FIND FILE FOR:monitor_xhc-hb04.tcl
[HAL]
HALFILE = monitor_xhc-hb04.tclThe monitor_xhc-hb04.tcl is *not* a HALFILE,
Example:
[APPLICATIONS]
APP = xhc-hb04-accels
APP = monitor-xhc-hb04Ref (README): github.com/LinuxCNC/linuxcnc/blob/2.7/co...xhc-hb04/README#L141
The following user(s) said Thank You: RobotMatic, tommylight, BeagleBrainz
Time to create page: 0.324 seconds
