xhc-hb04 .Why can't I make it work?
  • RobotMatic
  • RobotMatic's Avatar Topic Author
  • Elite Member
  • Elite Member
21 Mar 2020 22:58 #161064 by RobotMatic
Replied by RobotMatic on topic xhc-hb04 .Why can't I make it work?
yessssssss !!!!! delete line in group [hal] "HALFILE = monitor_xhc-hb04.tcl ". and run!!!!!
thankkkkkkkkkkkkkkkkkkkk!!!!!! a lot !!!!!!!!
  • RobotMatic
  • Elite Member
  • Elite Member
22 Mar 2020 09:41 - 22 Mar 2020 09:53 #161112 by RobotMatic
Hi !. These are the files of my machine with the HB04 wifi mpg working perfectly.
File Name: fresa-HB04...3-22.hal
File Size:4 KB
File Name: fresa-HB04...3-22.ini
File Size:5 KB
I have made the configurations that allow me the options in the .INI file of my machine.
now i am reprogramming macros
Thank you all for the great help you are giving me, I am learning little by little and I find it hard to understand how things work.
thanks!!!!
Last edit: 22 Mar 2020 09:53 by RobotMatic. Reason: thank
  • RobotMatic
  • Elite Member
  • Elite Member
22 Mar 2020 10:25 #161114 by RobotMatic
I leave here my files working with the remapping of some macro in case someone is useful.
thanks again !!!
File Name: fresa-HB04...22-2.hal
File Size:4 KB
File Name: fresa-HB04...22-2.ini
File Size:5 KB
28 Mar 2020 07:26 - 28 Mar 2020 07:29 #161797 by jirkam
Replied by jirkam on topic xhc-hb04 .Why can't I make it work?
Good day.
Can I ask for help?
I have tried several procedures but the HB04 is still not working properly.
After starting my configuration the HB04 works. The axis on the monitor moves but the HB04 LCD does not change.
When HB04 falls asleep and wakes him up with the "Start / Pause" button, it no longer works.
I have the same problem with all configurations.
Do I have something wrong installed?
I have a Linux CNCRouter 4.9.0-12-rt-686-pae # 1 SMP Preempt RT Debian 4.9.210-1 (2020-01-20) i686 GNU / Linux and LinuxCNC 2.9.0.
I have HB04 exactly as in the picture.
What am I doing wrong?
Thank you very much.
Last edit: 28 Mar 2020 07:29 by jirkam.
  • RobotMatic
  • Elite Member
  • Elite Member
29 Mar 2020 11:13 #161987 by RobotMatic
Hello, I am using the configuration files that I left in this post without problem, I do not have the capacity to help you, but I am using 2.7.15 the last release. Why are you using 2.9? you should use 2.8 pre-release on your yyxz router. could you tell me why?. thank
29 Mar 2020 11:42 #161998 by jirkam
Good day.
Thank you for your response.
I do not understand much.
I'm using EtherCAT. When installing LinuxCNC according to the instructions on the Internet, version 2.9.0 was installed. I thought it was ok. Version 2.9.0 is bad?
Can the HB04 be defective?
When I turn on the HB04 and turn the switch to all positions X, Y, Z, A, Spindle, Feed, nothing on the LCD will change.
It's OK?
When the switch is in the Spindle position and only then turn the HB04 on, the LCD will display "F 0.000 / S 0.000". But when switching to "X", nothing changes on the LCD display. It is also ok?
Thank you very much and have a nice day.
Jirka
  • RobotMatic
  • Elite Member
  • Elite Member
29 Mar 2020 12:03 #162004 by RobotMatic
hello, it is not about good or bad, the current version of linuxcnc is 2.7.15. the others have not been released yet but the developers allow the installation for testing.
I understand that pre-release version 2.8 is the next one to come out, and this version allows your xyyz configuration.
Have you not thought that perhaps your xhb04 device is damaged?
29 Mar 2020 12:50 #162010 by jirkam
I thought 2.9.0 was the official release.
Is it possible to downgrade from 2.9.0 to 2.8.0?
Yes. I thought the HB04 was damaged. The video on youtube switches from "X" to "Spindle" and the LCD display changes. For my HB04, the LCD does not change.
It may be damaged or is poorly loaded with Linux?
Jirka
  • RobotMatic
  • Elite Member
  • Elite Member
29 Mar 2020 13:08 #162011 by RobotMatic
I have done a test with mine.
If the device loses the connection, the screen turns off and although it is turned on nothing works, you have to restart everything.
I would think to check if your ethercat configuration is not bothering hxb04.
Why don't you do a basic configuration with the simulator, and load the xb04 to see if your device really works. you can use my files directly.
29 Mar 2020 13:44 #162013 by jirkam
I tested the basic configuration "xhc-hb04-layout2_mm" 14 days ago. And it still reacts the same way. I've been bothering about it ever since.
Thank you jirka
Time to create page: 0.274 seconds
