Fake encoder index for simulation
- mydani
- Banned
- Thank you received: 9
13 Apr 2020 02:41 #163849
by mydani
Fake encoder index for simulation was created by mydani
for G33, an encoder index is required. Any idea whether there is a hack already available for simulation?
If not, I guess some simple comp which, based on requested spindle speed, could fake an index signal.
Regards,
Daniel
Regards,
Daniel
- Thank you received: 2182
13 Apr 2020 12:32 #163893
Replied by cmorley on topic Fake encoder index for simulation
I'm pretty sure there is; the lathe simulated configs fake encoder indexing.
- mydani
- Banned
15 Apr 2020 02:27 - 15 Apr 2020 02:28 #164027
by mydani
Replied by mydani on topic Fake encoder index for simulation
Ah, thanks for the hint. Of course it's there.
For anyone searching, there's a comp sim_encoder.
loadrt sim_encoder names=sim_encoder_0
net spindle-phase-Z sim_encoder_0.phase-Z => encoder_0.phase-Z
# assume 120 ppr = 480 counts/rev for the spindle
setp sim_encoder_0.ppr 12
# iocontrol output is in rpm, but sim-encoder speed is rps
setp sim_encoder_0.scale 60
# scale encoder output to read in revolutions (that way thread pitches can be straightforward, a 20 tpi thread would multiply the encoder output by 1/20, etc)
setp encoder_0.position-scale 48
addf sim-encoder.update-speed servo-thread
addf sim-encoder.make-pulses base-thread
Last edit: 15 Apr 2020 02:28 by mydani.
- GM2012
14 Oct 2021 08:08 #223082
by GM2012
Replied by GM2012 on topic Fake encoder index for simulation
I do not use HAL as CNC is just my hobby and do not want to spend time learning HAL. I usually find what I need, but this time having trouble with this sim-encoder.
Anyone actually tested sim-encoder? Above posted code actually doesn't work. There is a sim_encoder_0 but also there is encoder_0. I could add line:
loadrt encoder names=encoder_0
and it 'works'.
I am not sure if simulated encoder can be used to replace a real encoder?
I have a small cnc lathe where I want to run spindle with external stepper (for threading). Lathe is custom build with Sherline head. As steppers (normally) do not have encoders why we cannot have a spindle run with a stepper without an encoder? We can assume that spindle will spin with constant RPM as we use stepper.
When I try threading with G76 .. gettting message "spindle not turning in G76".
I don't know if it is possible to display simulated spindle RPM in GUI? In HAL configuration I can only see sim-encoder.make-pulses and sim-encoder.update-speed changing in "watch".
In this simulated encoder I don't see something that would simulate spindle is turning.
Any help is appreciated.
and it 'works'.
- Thank you received: 4660
14 Oct 2021 11:09 #223095
Replied by andypugh on topic Fake encoder index for simulation
sim_encoder actually simulates an encoder, not an encoder counter.
linuxcnc.org/docs/2.8/html/man/man9/sim_encoder.9.html
ie it takes a velocity as input and outputs A,B,Z pulses.
The partial example you are copying only indicates how the sim-encoder has been hooked up to an already-existing encoder counter (encoder.0) for simulation.
To thread with a stepper motor spindle, and with no actual encoder, I would suggest a custom HAL component. It would need to take index-enable and stepgen rawcounts as input, and would output position and reset the index-enable.
I can write it for you, but you need to be willing to learn enough HAL to make use of it...
The following user(s) said Thank You: GM2012
- GM2012
15 Oct 2021 19:07 - 15 Oct 2021 19:16 #223262
by GM2012
I was able to install, use and understand Logitech "pendant". Problem is that I forget HAL as I don't use it often but can understand most of it. Any help in this direction is appreciated. I can really buy an encoder with two pulleys and install it and I know it will work. Just being cheap
. I do not cut threads to often. Have Sherline spindle thread attachment but it is hard to use in my opinion.
Meantime .. I've got an idea (and I am sure it is possible), to run my Spindle with 1rotation/sec, then run X-axis with properly calculated speed to cut thread with a simple g-code. Trying to find an answer how I can move X-axis and A-axis with a different feed rates at the same time. So far no luck, but maybe I'll find out.
And forgot to add .. small CNC lathe (for G-code 'idea') is connected to my-mill, X axis and spindle to A-axis.
Last edit: 15 Oct 2021 19:16 by GM2012.
18 Oct 2021 18:21 - 09 Jun 2023 08:07 #223508
Save the following as "stepperspindle.comp" and compile / install it with
in the HAL file
Here is the component:
sudo halcompile --install stepperspindle.compin the HAL file
loadrt stepperspindle
addf stepperspindle.0 servo-thread
net spindle-counts stepgen.2.rawcounts stepperspindle.0.rawcounts
net spindle-index-enable spindle.0.index-enable stepperspindle.0.index-enable
net spindle-pos stepperspindle.0.revs spindle.0.revs
setp stepperspindle.0.steps-per-rev 1600Here is the component:
component stepperspindle "Allow threading with stepper spondle and no encoder";
pin in signed rawcounts "connect to the stepgen rawcounts pin";
pin io bit index-enable "connect to index-enable";
pin out float spindle-revs "connect to spindle.0.revs";
param rw signed steps-per-rev = 100 "stepper steps per rev / per index";
license "GPL";
author "andypugh";
function _;
FUNCTION(_){
static rtapi_s64 counts;
static rtapi_s64 offset;
static int last_counts;
static int last_index;
// Handle rawcounts wrapping
counts += rawcounts - last_counts;
last_counts = rawcounts;
// handle index-enable
if (index_enable){
if (! last_index){ // new index-enable
offset = counts - (counts % steps_per_rev) + steps_per_rev;
} else if (counts > offset){ // passed virtual index
offset = counts - (counts % steps_per_rev);
index_enable = 0;
last_index = index_enable;
// calculate position
spindle_revs = (counts - offset)/ (float)steps_per_rev;
Last edit: 09 Jun 2023 08:07 by andypugh.
The following user(s) said Thank You: GaryLa
- GM2012
19 Oct 2021 13:20 #223587
by GM2012
Andy, didn't have time yet to implement and check but thank you so much!
- GaryLa
17 Mar 2023 07:27 - 18 Mar 2023 09:54 #266910
by GaryLa
Replied by GaryLa on topic Fake encoder index for simulation
Thanks for the well-written example.
For those who might use this with a MESA board, change stepgen "rawcounts" to hostmot2's "counts"
So instead of:
use:
Also, I commented out the below PNCCONF code because it conflicted with the example andy gave:
From the example:
Also, hostmot2 exports as 2-digit numbering:
stepgen.00.counts, versus stepgen.0.rawcounts although it may still work as single-digit, I didn't try it.
So instead of:
net spindle-counts stepgen.2.rawcounts stepperspindle.0.rawcountsuse:
net spindle-counts hm2_7i96s.0.stepgen.00.counts stepperspindle.0.rawcountsAlso, I commented out the below PNCCONF code because it conflicted with the example andy gave:
#net spindle-revs => spindle.0.revs #already used aboveFrom the example:
net spindle-pos stepperspindle.0.spindle-revs spindle.0.revsAlso, hostmot2 exports as 2-digit numbering:
Last edit: 18 Mar 2023 09:54 by GaryLa. Reason: updated
- drummond
- Thank you received: 5
20 Mar 2023 16:12 #267186
by drummond
Replied by drummond on topic Fake encoder index for simulation
What a great set of posts!
Thanks to everyone that posted, but particularly Andy for putting together that component and GaryLa for expanding the idea to mesa card users.
The search facility on this forum doesn't work as well as it could so I've come to the conclusion that bookmarking threads like these is the best way to go.
Time to create page: 0.407 seconds
