Fake encoder index for simulation
08 Jun 2023 16:32 #273218 by drummond
Replied by drummond on topic Fake encoder index for simulation
I got around to trying this, with little hope for success because I'm currently running the lathe spindle with a stepper motor in velocity mode and I wasn't sure how I might integrate stepperspindle.
I'm using 2.8.4 on an RPI4 with 7C81
It was an interesting exercise getting Halcompile to work, but I learned that raspbian responds to a right click on a file with a menu that includes "copy path(s)", click on that and you can paste the complete path into a terminal.
Once I had the comp file compiled and installed, I added the HAL entries as originally shown along with the amendments suggested by GaryLa
I loaded linuxcnc from a terminal (it's easier to find errors this way)  it didn't finish loading but:
./turner.hal:207: Pin 'stepperspindle.0.revs' does not exist
line 207 read: net spindle-pos stepperspindle.0.revs motion.spindle.0.revs
commenting it out resulted in linuxcnc loading without error.
a look at halshow pins under stepperspindle then 0 showed no pin with that name, but there was a very similar stepperspindle.0.spindle-revs and subbing this in resulted in that error going away, but
./turner.hal:207: Pin 'motion.spindle.0.revs' does not exist
Rinse and repeat finds we just need spindle.0.revs without the 'motion'
Now it loads without error.
Does it work, well that's a story for another day
08 Jun 2023 17:24 - 09 Jun 2023 09:34 #273220 by PCW
Replied by PCW on topic Fake encoder index for simulation
Note that you can use index with step/dir driven spindles
with LinuxCNC 2.9 and Mesa cards with the correct firmware.
This allows spindle synchronized moves without an encoder,
though an index input is still required.
Last edit: 09 Jun 2023 09:34 by PCW. Reason: clarify
09 Jun 2023 08:08 #273237 by andypugh
Replied by andypugh on topic Fake encoder index for simulation
Sorry, that was an error on my part, I typoed the older pin name by accident (now fixed in the original post)
09 Jun 2023 16:17 #273251 by drummond
When I look at HAL configuration there are four pins associated with Stepperspindle: index-enable, rawcounts, spindle-revs, time.
I'm running the lathe motor with the following in the ini file:
MOTOR_SCALE 3200 // stepper takes 3200 steps per revolution
STEP_SCALE  1600 // lathe spindle has a 2:1 relationship with the motor, stepper revolves once, lathe spindle revolves twice.
I wondered how this might gel with:
setp stepperspindle.0.steps-per-rev 1600
Which went in HAL file per the original instructions, it seems correct- but how could I be so lucky?
Got the motor running and watched the first 3 pins.
Results:
index-enable=nothing
rawcounts=count is going but with a minus sign in front of it
spindle-revs=count is going but with a minus sign in front of it
I can "correct" the minus on spindle revs by changing the HAL entry to:
setp stepperspindle.0.steps-per-rev -1600, which feels wrong somehow because the originals in the ini file are both positive and produce counterclockwise rotation with M4
rawcounts seems less trivial to fix
from the comp file:
.......signed steps-per-rev = 100 "stepper steps per rev / per index";
If that means what I think it means it will produce indexes far more frequently than I was expecting?
10 Jun 2023 06:06 #273266 by andypugh
Negative scales are not unusual to reverse specific functions.
Counts being negative is not a problem for the fake index comp.
But I suspect that you might have a misconfiguration if M4 is normal rotation unless this is a back-tool lathe.
Looking down the spindle towards the tailstock, M3 should be clockwise and count up.
10 Jun 2023 11:16 #273273 by drummond
Well, that was a typo combined with an interruption leading to an incomplete message being sent (!) Sorry about that
What it should have read is: "the originals in the ini file  are NOW both positive and produce counterclockwise motion with M3, to correct this I have to set them both back to negative
I could never get to watch the index changing by watching it on HAL configuration even with a spindle speed of 1 rpm (stepper running at 0.5 rpm)
I tried a simple g33 routine "in air" and everything seems to work, spindle synchronized motion without an encoder.  Thank you.
