- Thank you received: 18
yalang yl620 VFD rs485/modbus communicaiton
- aekhv
6 years 5 months ago #168841
by aekhv
Replied by aekhv on topic yalang yl620 VFD rs485/modbus communicaiton
An interesting info about YL620 and electrical noises:
forum.linuxcnc.org/24-hal-components/341...2hal?start=20#153160
I'm using this adapter (with other VFD, not a YL620), it works fine for me: aliexpress.ru/item/32811301007.html
BTW if you consider this VFD, dont!
If you have massive noise problems, you've been warned.
Schaffner FN2060-16-06 mains filter will help a lot (my DAB! radio works now) and ferrite bead(donut shaped ring) on rs485 line will stop your screen from going wonky.
- rounyworks
5 years 2 months ago - 5 years 2 months ago #219281
by rounyworks
Replied by rounyworks on topic yalang yl620 VFD rs485/modbus communicaiton
please help me i'm problem wih this vfd
Opening /dev/ttyUSB0 at 9600 bauds (N, 8, 1)
vfdmod: reading 'spindle.rpm-out' from address 8203 (0x200B)...
[01][03][20][0B][00][01][FE][08]
Waiting for a confirmation...
<01><83><03><01><31>
ERROR Illegal data value
vfdmod: setting command speed value to 500 (0x01F4)...
[01][06][20][01][01][F4][D3][DD]
<01><86><03><02><61>
Last edit: 5 years 2 months ago by rounyworks.
5 years 1 month ago #219381
Replied by andypugh on topic yalang yl620 VFD rs485/modbus communicaiton
Are you sure that 9600 / N / 8 / 1 is correct for the VFD?
- rounyworks
5 years 1 month ago #219475
by rounyworks
Yes this my VFD setting
P00.01 = 3
P03.00 = 3
P03.01 = 1
P03.02 = 2
P07.08 = 5
P00.01 = 3
P03.00 = 3
P03.01 = 1
P03.02 = 2
P07.08 = 5
- iforce2d
- Thank you received: 17
5 years 1 month ago #219499
by iforce2d
Replied by iforce2d on topic yalang yl620 VFD rs485/modbus communicaiton
I recently spent two days trying to get RS485 working with this VFD before giving up. It appears to be simply reject any communication on that external port no matter what settings are made. My reports in this thread might be interesting, but there's nothing good:
forum.linuxcnc.org/24-hal-components/387...-rtu?start=60#218634
I would suggest just using PWM control, takes about 10 minutes to set up. If only I had a time machine...
5 years 1 month ago #219525
FWIW the HuangYang VFDs have the same problem, they don't actually talk modbus. The dedicated driver handles this.
It _might_ be worth trying the hy_vfd driver with this one. The worst that can happen is that you waste even more time.
Time to create page: 7.998 seconds
