Remote HAL commands e.g. ESTOP possible?
06 Jun 2020 04:00 #170326 by mydani
Hi all,
just wondering, as I check on my running machines sometimes from a floor above via camera, whether I could send hal cmds to the running linuxcnc instance via logging into the machine terminal. Tried it, using haltcl, will tell me the rtapi module is not loaded, etc...
Maybe you guys did this already?
Regards,
Daniel
06 Jun 2020 04:56 #170330 by mydani
Replied by mydani on topic Remote HAL commands e.g. ESTOP possible?
AH - it helps to use the right linuxcnc instance and rip environment...
Thanks tommy for confirmation!
  • Moderator
  • Moderator
06 Jun 2020 05:06 #170331 by tommylight
Replied by tommylight on topic Remote HAL commands e.g. ESTOP possible?
No need for RIP, buildbot will also work, or a normal installation.
06 Jun 2020 06:15 #170345 by bbsr_5a
Replied by bbsr_5a on topic Remote HAL commands e.g. ESTOP possible?
be very carfull on direct interpreter commands
as special to interfear e-stop behavior from faraway
06 Jun 2020 17:00 #170414 by rodw
Replied by rodw on topic Remote HAL commands e.g. ESTOP possible?
By design it is possible to seperate the GUI to another PC on a network. There is a config file somewhere that sets this up which defaults to localhost by default.. I've never played
Time to create page: 0.093 seconds
