Problem with toogle2nist component
- mwinterm
- Thank you received: 13
08 Nov 2020 12:18 #188678
by mwinterm
Problem with toogle2nist component was created by mwinterm
Hello,
I'm trying to implement a physical button to start/stop the spindle. To do so I try to use the toggle2nist component the following way:
This does not work as supposed. The spindle is stopping as long as I keep the button pressed and starting again as soon as I release it. The following workaround where I delay the spindle-enable signal is providing the desired result.
However I don't understand why this hack is needed. Could it be connected to the sequence the HAL execution?
Further, what would be the right way to initialize a toggle or toggle2nist component to be in a specific state on start-up?
Regards,
Marc
PS: spindle-enable has the following connections:
# --- SPINDLE-BUTTON ---
net spindle-button toggle2nist.0.in <= hm2_7i76e.0.7i76.0.0.input-25
net spindle-enable => toggle2nist.0.is-on
net spindle-manual-start toggle2nist.0.on
net spindle-manual-stop toggle2nist.0.offThis does not work as supposed. The spindle is stopping as long as I keep the button pressed and starting again as soon as I release it. The following workaround where I delay the spindle-enable signal is providing the desired result.
net spindle-enable => timedelay.0.in
net spindle-enable-delayed toggle2nist.0.is-on <= timedelay.0.out
net spindle-manual-stop toggle2nist.0.offHowever I don't understand why this hack is needed. Could it be connected to the sequence the HAL execution?
Regards,
Marc
net spindle-enable => pid.s.enable
net spindle-enable => hm2_7i76e.0.7i76.0.0.spinena
net spindle-enable <= spindle.0.onPlease Log in or Create an account to join the conversation.
- Thank you received: 2181
08 Nov 2020 12:33 #188679
Replied by cmorley on topic Problem with toogle2nist component
What does spindle-manual-start/spindle-manual-stop connect to.
also what is the addf sequence for the components.
addf sets the sequence that components are evaluated and it can mean a component id evaluating old data.
- mwinterm
08 Nov 2020 13:11 #188683
by mwinterm
and here the addf-statements:
Replied by mwinterm on topic Problem with toogle2nist component
net spindle-manual-stop halui.spindle.0.stop
net spindle-manual-start halui.spindle.0.startand here the addf-statements:
addf hm2_7i76e.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf ratio_select servo-thread
addf scale.gear servo-thread
addf hm2_7i76e.0.write servo-thread
setp hm2_7i76e.0.dpll.01.timer-us -50
setp hm2_7i76e.0.stepgen.timer-number 1
addf and2.0 servo-thread
addf and2.1 servo-thread
addf spindle-scale servo-thread
addf conv-float-s32.0 servo-thread
addf feed-scale servo-thread
addf conv-float-s32.1 servo-thread
addf rapid-scale servo-thread
addf conv-float-s32.2 servo-thread
addf toggle.0 servo-thread
addf toggle2nist.0 servo-thread
addf timedelay.0 servo-threadPlease Log in or Create an account to join the conversation.
08 Nov 2020 16:53 #188706
My guess is the servo thread updates faster then the HALUI component does.
HALUI is userspace so it's update is a little unpredictable but should be about 100ms IIRC.
Please describe completely what you are trying to do and maybe we can find a different way or just live with the time delay - it works !
Chris
Chris
- mwinterm
11 Nov 2020 09:17 #189008
by mwinterm
Replied by mwinterm on topic Problem with toggle2nist component
Hello Chris,
this makes sense to me and knowing what the problem is I think I can live with my workaround for the moment.
However I'm facing another problem with toggle2nist: When I'm starting LinuxCNC toggle2nist immediately tries to do a switch-action (not sure if it is from on to off or other way around). As at start-up E-stop is still active this causes rightfully an error.
Here is the code from toggle2nist from that I found on GitHub:I'm pretty new to linuxcnc and have no experience in HAL component programming so far. However based on my general understanding of programming I think there could be a problem withnot being initialized on start-up and therefore having an arbitrary value most likely not being 0 or 1. With that when run the first time in the servo-thread it meets the first if-condition and therefore causes an immediate switch-action.
If my assumptions are correct a solution could be to add an additional initialization parameter that defines old_in when the HAL file is executed.
Does this make any sense?
Regards,
Marc
component toggle2nist "toggle button to nist logic";
description
toggle2nist can be used with a momentary push button connected to a
toggle component to control a device that has separate on and off inputs
and has an is-on output.
If in changes states via the toggle output
If is-on is true then on is false and off is true.
If is-on is false the on true and off is false.
pin in bit in;
pin in bit is_on;
pin out bit on;
pin out bit off;
variable int old_in;
variable int to_state=0;
function _ nofp;
license "GPL";
FUNCTION(_) {
if (in!=old_in) /* a toggle has occurred */ {
if (is_on) { /* turn OFF if it's on */
on=0;
off=1;
to_state=0;
else if (!is_on) { /* turn ON if it's off */
on=1;
off=0;
to_state=1;
else {
/* reset pins when we see the desired state */
if (to_state==is_on) {
on=0;
off=0;
old_in=in;
}variable int old_in;If my assumptions are correct a solution could be to add an additional initialization parameter that defines old_in when the HAL file is executed.
Regards,
Marc
- mwinterm
13 Nov 2020 16:57 #189267
by mwinterm
...no one with any feedback on this?
Regards,
Marc
Regards,
Marc
- Thank you received: 7504
13 Nov 2020 17:13 #189269
Replied by tommylight on topic Problem with toggle2nist component
You can do some quick tests to check if it "misses", just load it in a sim config and check the sates with halshow or halscope or "show hal configuration" from the machine menu.
- Benb
- Thank you received: 61
21 Nov 2020 21:51 #190021
by Benb
Replied by Benb on topic Problem with toogle2nist component
Attached is a cartoon showing similar hal file to toggle2nist with couple of interlocks to prevent signal racing. I have not tested this configuration, but its start.
21 Nov 2020 23:07 #190023
Replied by cmorley on topic Problem with toggle2nist component
you could compile a new component and try your fix to see if it helps.
linuxcnc.org/docs/devel/html/hal/comp.ht...side_the_source_tree
- mwinterm
26 Nov 2020 14:46 #190367
by mwinterm
@cmorley: Thanks for the link, that is exactly what I'm currently looking into (once I find a little more time again...)
@Benb: that is also very nice work, even though I try to keep the logical programming in the HAL file to a minimum (I'm more a higher level language coder...
. However you have made a very nice schemata. Do you have a tool to create this directly from the *.hal file?
Best regards,
Marc
Best regards,
Marc
Time to create page: 0.142 seconds
