Problem with toogle2nist component
- rootboy
- Thank you received: 25
27 Nov 2020 03:43 #190393
by rootboy
Replied by rootboy on topic Problem with toogle2nist component
Try adding a toggle component to feed your toggle2nist component. The toggle component comes with a debounce delay, which sounds like what you need.
net toggle-ok toggle.1.in <= or2.1.out
net togglesig toggle2nist.0.in <= toggle.1.out
net toggleon halui.program.pause <= toggle2nist.0.on
net toggleoff halui.program.resume <= toggle2nist.0.off
Found here:
pastebin.com/NFHf6Px9
Found here:
28 Nov 2024 12:07 #315456
Replied by andypugh on topic Problem with toogle2nist component
This should have been fixed now:
github.com/LinuxCNC/linuxcnc/commit/0bc9...000f4da3e4ba393b65c3
The new version is only in the development version of LinuxCNC at the moment.
You can install it on your own installation with:
1) Install LinuxCNC dev to get the "halcompile" tool.
2) Download this file and save it to your PC
raw.githubusercontent.com/LinuxCNC/linux...nts/toggle2nist.comp
3) Install it
sudo apt-get install linuxcnc-uspace-dev2) Download this file and save it to your PC
3) Install it
sudo halcompile --install toggle2nist.compPlease Log in or Create an account to join the conversation.
- blazini36
- Thank you received: 167
21 Jan 2025 17:22 #319578
by blazini36
Replied by blazini36 on topic Problem with toogle2nist component
Problem with toggle2nist is the name of the is-on pin. Halui uses the is-on name as an output for lots of pins so it tripped me up expecting that to be an output pin. It's an input pin that absolutely must be connected to the is-on output or the component can't transition to the next state. They should have named it "on-state" or something.This should have been fixed now:
1) Install LinuxCNC dev to get the "halcompile" tool.[/code]sudo apt-get install linuxcnc-uspace-dev 2) Download this file and save it to your PC https://raw.githubusercontent.com/LinuxCNC/linuxcnc/refs/heads/master/src/hal/components/toggle2nist.comp 3) Install it [code]sudo halcompile --install toggle2nist.comp
- maxi177
- Thank you received: 3
02 Mar 2026 07:34 #343717
by maxi177
Replied by maxi177 on topic Problem with toogle2nist component
Did the fixed version of toggle2nist made it to a released version of linuxcnc? I'm not really familiar with git, so I can't tell myself...
05 Mar 2026 16:52 #343900
No, there hasn't been a 2.10 release, and that was the development version when my email was sent.
This is the state of the .comp in the 2.9.8 release tag.
github.com/LinuxCNC/linuxcnc/blob/v2.9.8...nts/toggle2nist.comp
(no debounce pins)
(no debounce pins)
Time to create page: 0.095 seconds
