New component for keyboards and panels.
- abdulasis12
- Thank you received: 8
17 May 2024 02:56 #300805
by abdulasis12
Replied by abdulasis12 on topic New component for keyboards and panels.
Hi
Thank you for reply ,Aciera tommylight COFHAL
Today I test
MODE="XXXX" this xxx, by below
0660
0666
777
0777
all chmod will remove permission after reboot PC
forum.linuxcnc.org/24-hal-components/415...nels?start=90#300763
MR.MarkoPolo can you explain and step by step for setup this ?, I want to try , sorry I poor linux program.
Thank you.
Today I test
0660
0666
777
0777
Thank you.
- MarkoPolo
- Thank you received: 90
17 May 2024 05:19 #300813
by MarkoPolo
Replied by MarkoPolo on topic New component for keyboards and panels.
try this:
sudo nano /etc/cron.d/uinput
complete the file with the content: @reboot root chmod 666 /dev/uinput
(at the end of the line press etner to end the line)
save the file and exit
reboot
reboot
The following user(s) said Thank You: pietvr, abdulasis12
- abdulasis12
17 May 2024 11:06 #300836
by abdulasis12
This work !!!
Thank you, MR.MarkoPolo
AWSOME !try this:
reboot
This work !!!
- MarkoPolo
17 May 2024 11:17 #300838
by MarkoPolo
I'm glad it works.
this is an even simpler version if anyone needs something similar. Just paste into the console and enter the password.
echo "@reboot root chmod 666 /dev/uinput" |sudo tee /etc/cron.d/uinput
The following user(s) said Thank You: tommylight, pietvr, abdulasis12
Time to create page: 0.093 seconds
