Halsampler tools
4 years 6 months ago - 4 years 6 months ago #239925 by turbostew
Replied by turbostew on topic Halsampler tools
Here is my heavy modified version...... This module does not have the display all fields if no fields specified feature.  It does xy plots and has sample delay option.  You can also hide a field, this is so you can use the field (with scaling/samp delay) for x values in xy plot without the field also being plotted on a time scale.
Last edit: 4 years 6 months ago by turbostew.
4 years 6 months ago #240064 by rgb
Replied by rgb on topic Halsampler tools
Thanks! I'll take a look at your changes.
Bob
4 years 6 months ago #240426 by rgb
Thanks for the code @trubostew. I liked your idea of doing the options work in the numpy array rather than trying to do it all in the main loop. The change simplified the option processing. I added your delay option as well. My new version is in github now.
4 years 6 months ago #241403 by turbostew
Glad my code was usefull.  Thanks!
Time to create page: 0.245 seconds
