- Thank you received: 7
Spindle indexing signal direction
- rider-83
- Topic Author
4 years 9 months ago #233863
by rider-83
Spindle indexing signal direction was created by rider-83
When using G76, the lathe works correctly with M3, but sits and waits with M4
Would the issue be related to:
net spindle-index-enable encoder.0.index-enable <=> spindle.0.index-enable
Any help appreciated.
Thanks,
Thanks,
- rider-83
- Topic Author
4 years 9 months ago #233901
by rider-83
Replied by rider-83 on topic Spindle indexing signal direction
In my .hal file, Should I be using : spindle.N.revs
- rider-83
- Topic Author
4 years 9 months ago #233903
by rider-83
Is there anyone out there ???
4 years 9 months ago #233905
Replied by tommylight on topic Spindle indexing signal direction
Yes there is, but since i never used G76, i can not help.
- Thank you received: 3485
4 years 9 months ago #233909
Replied by PCW on topic Spindle indexing signal direction
I dont think this is index related.
is spindle-at-speed true?
- rider-83
- Topic Author
4 years 9 months ago #233946
by rider-83
Thats fine. Thank you for the relpy, I was begining to think I was on my own out here
- rider-83
- Topic Author
4 years 9 months ago #233947
by rider-83
"is spindle-at-speed true? "
Good question.
When I use G96 (CSS) and G1 with either M3 or M4, then the machine feeds fine.
So I could say , yes "spindle-at-speed true? " is fine.
However,
If I use G76 with M3, all works fine as well.
If I use G76 with M4, then the machine hangs in position waiting.
Therefor I could say that 'spindle-at-speed true' is functioning, however there may be a set of conditions were 'spindle-at-speed true' is'nt 'true' in the case of M4 & G76 that satisfy 'index' ??
Good question.
However,
4 years 9 months ago #233970
It looks like G76 with M4 needs hal changes:
forum.linuxcnc.org/forum/38-general-linu...h-spindle-in-reverse
- rider-83
- Topic Author
4 years 9 months ago - 4 years 9 months ago #233971
by rider-83
Eewww. That looks messy. Is there not an easier way?
(By the way PCW, thank you so much for the reply and finding this information)
Last edit: 4 years 9 months ago by rider-83.
- rider-83
- Topic Author
4 years 9 months ago #233972
by rider-83
Out of interest I've been playing around with HALshow.
If I turn the spindle by hand so the 'Z' phase notch in the encoder wheel passes through, then I get the below conditions:
SPINDLE-INDEX = becomes TRUE
ENCODER.0.PHASE-Z = becomes TRUE
However,
SPINDLE-INDEX-ENABLE = stays false at all times
ENCODER.0.INDEX-ENABLE=stays false at all times
SPINDLE.0.INDEX-ENABLE=stays false at all times
Is this normal ?
However,
Is this normal ?
Time to create page: 0.205 seconds
