Spindle indexing signal direction
13 Feb 2022 15:19 #234701 by Clive S
Replied by Clive S on topic Spindle indexing signal direction
Is the Z index 1:1 on the spindle ?
Does the Z move the correct amount when commanding say G0 Z - 50 and it actually  moves 50mm
13 Feb 2022 15:29 - 13 Feb 2022 15:30 #234703 by rider-83
Replied by rider-83 on topic Spindle indexing signal direction
Yes,
I did some test a while ago to check positioning and repeatably and I'm very please with the results.
I've noticed also that feed rates per rev have to be set very low .
For example, I'm having to rough feed at around F0.05, and finish at around F0.01.
Something is amiss here.
Last edit: 13 Feb 2022 15:30 by rider-83.
13 Feb 2022 15:59 #234705 by Clive S
Yes,
Not sure what you mean by that !!
If you are threading can you show the gcode you are using
The feed rate is controlled by the pitch
13 Feb 2022 16:12 #234708 by rider-83
I'm away from the machine right now, so I will have to get the G76 data later.
What I'm trying to say is that the feed rates that relate to rpm seem to be out.Almost as if it is not reading the rpm encoder feedback correctly.
14 Feb 2022 12:21 #234812 by rider-83
What would cause the encoder velocity-rpm via HALshow to jump all over?
At a commanded 100rpm we see readings drop down to 89 then upto 225.
Nothing stable around 100?
14 Feb 2022 13:28 #234819 by tommylight
Replied by tommylight on topic Spindle indexing signal direction
Bad encoder, bad/wrong wiring, no shielded wires, interference, bad power supply.
14 Feb 2022 18:44 #234846 by rider-83
Yes, that's a good statement, and I don't doubt you.
However, the pitch error whilst screw cutting is perfectly consistent with each pass.
This would suggest I may have made an error in my configuration perhaps?
14 Feb 2022 19:24 #234854 by Clive S
What is the gcode you are using?
14 Feb 2022 19:39 #234857 by rider-83
G76.
I tried to cut an M10 thread (1.5p) so I could check it with a standard nut.
Thread is measuring 0.75 approx. pitch with the RPM at 500
If I alter the G97 speed and try a fresh piece of bar to screw cut again to M10, the pitch will vary as I increase the revs. The pitch becomes finer. The pitch isn't consistent with any alteration of a new RPM.
Also, when feeding with G1 , the feed rates aren't what I would usually expect.
I hope I make sense with this.
14 Feb 2022 19:50 #234858 by Clive S
G76.
There is more than one flavour G76
This is why I was asking to see the actual Gcode that you are using
Time to create page: 0.135 seconds
