Fans to turn on when starting program
- remon_v
- Thank you received: 7
20 Feb 2022 11:27 - 20 Feb 2022 11:28 #235400
by remon_v
Replied by remon_v on topic Fans to turn on when starting program
Oke, so I'm adding a Xbox controller and I would like to assign a button 'B' to also be able to switch the fans on.
I've replace the 'or2' command by the 'logic' command.
Everything still works as expected, only when I press button B it triggers the fans, but I have to hold it down. When I release it, it turns off again.
So I'm guessing I need another toggle output or so?
I've attached my hal file... thanks in advance!
Last edit: 20 Feb 2022 11:28 by remon_v.
- remon_v
24 Feb 2022 02:05 - 24 Feb 2022 02:06 #235681
by remon_v
Last edit: 24 Feb 2022 02:06 by remon_v.
- MaHa
- Thank you received: 241
24 Feb 2022 04:35 #235683
by MaHa
Replied by MaHa on topic Fans to turn on when starting program
The following user(s) said Thank You: tommylight, remon_v
- remon_v
24 Feb 2022 12:00 #235733
by remon_v
It works! Many many thanks (again)!
Before asking I tried a few things, also to add or2.1, but what I didn't know is I had to add ' count=2' after the loadrt or2...
