External E-Stop
6 years 1 month ago #182044 by dennis.lewis5
Replied by dennis.lewis5 on topic External E-Stop
I cannot speak to the messaging you asked about but I am working on a system to tell me if the e-stop is the pc (as in startup) a local e-stop (one mounted on the machine) or a remote e-stop. The system simply operates a beacon and the flashing rate of the beacon indicates the trouble spot. It will force the pc into e-stop if local or remote.
If you have any interest please let me know.
5 years 10 months ago #193518 by ikkuh
Replied by ikkuh on topic External E-Stop
dennis.lewis5 wrote: I cannot speak to the messaging you asked about but I am working on a system to tell me if the e-stop is the pc (as in startup) a local e-stop (one mounted on the machine) or a remote e-stop. The system simply operates a beacon and the flashing rate of the beacon indicates the trouble spot. It will force the pc into e-stop if local or remote.
Yes, please. Most people here learn better by examples then reading abstract manuals. So I am certainly interested in your system.
5 years 10 months ago #193685 by dennis.lewis5
Thanks for your interest. I have (hopefully) attached a pdf with a description and photo of the e-stop module. A copy of the schematic is included as well.
If you would like to build one I have boards available as well as the pic micro.
Regards, Dennis
And Happy New Year.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
5 years 10 months ago - 5 years 10 months ago #193704 by rodw
Replied by rodw on topic External E-Stop
I had to say it. I don't think its necessary to use hardware to achieve what your board does. You could use the sigggen component to flash the lights. Here is an example which i now have running stack lights. The green light flashes and you could apply the same approach to the red light for estop.
Last edit: 5 years 10 months ago by rodw.
The following user(s) said Thank You: Unlogic
5 years 9 months ago #194186 by dennis.lewis5
Interesting. This could be implemented if I had enough i/o. Since I am using a single parport that is kind of scarce.
5 years 9 months ago #194187 by rodw
dennis.lewis5 wrote: Interesting. This could be implemented if I had enough i/o. Since I am using a single parport that is kind of scarce.
Add a second par port? Might have been a lot easier.. and cheaper
Time to create page: 0.293 seconds
