Temporarily Disable Signal to Servo Amp
- hunterlong
09 Jan 2023 19:45 #261401
by hunterlong
Temporarily Disable Signal to Servo Amp was created by hunterlong
I was wondering how to temporarily disable the analog output of the pid for the z axis? During a tool change I believe I'm making the amp overcurrent fault when the drawbar is pushed down. It moves the z axis about 0.05" down.
I would like to disable the analog out for the z axis, do the tool change, then re-enable it.
If it was at a position of say 0.3" before I disabled it, and it got pushed down to 0.25", when re-enabled could it just move back to the original position of 0.3"?
Thanks,
Hunter
Thanks,
Hunter
- Thank you received: 7504
09 Jan 2023 20:21 #261408
Replied by tommylight on topic Temporarily Disable Signal to Servo Amp
Read about this in the other topic, thinking about it, i am sure LinuxCNC does this for tandem axis/joints, but i am not sure if it will work for a single axis, although i see no reason why it should not.
No idea how to implement it for now, need sleep, 3AM here.
The following user(s) said Thank You: hunterlong
- hunterlong
09 Jan 2023 20:36 #261410
by hunterlong
Replied by hunterlong on topic Temporarily Disable Signal to Servo Amp
I see the pid component has a pin:
pid.N.enable bit in
When true, enables the PID calculations. When false, output is zero, and all internal integrators, etc, are reset.
Maybe I could wire up to this in classic ladder?
-Hunter
pid.N.enable bit in
-Hunter
09 Jan 2023 20:49 #261412
I would not use classic ladder for that, keep it in hal.
Hal has "and" "or" "xor" logic components included.
- hunterlong
10 Jan 2023 07:25 - 10 Jan 2023 07:28 #261443
by hunterlong
Cool, well just correct me if anything I say is nonsensical. I'm a noob
The way my tool change works now is I have in my *.ini file
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOL_CHANGE_QUILL_UP = 1
TOOL_CHANGE_POSITION = 0 0 0.300
So when I get an M6T1 command the z-axis moves up to 0.300". Then there is a button on the machine I push wired up to classic logic. Q2 is the z-axis lock bar, Q1 lowers the pin to the drawbar, and Q0 extends the pin that releases the drawbar/tool.
I was thinking I would could just wire Q1 to pid.N.enable bit in as well so that while the drawbar is being pushed down the pid for the z axis is disabled as well.
-Hunter
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
-Hunter
Last edit: 10 Jan 2023 07:28 by hunterlong. Reason: Image didn't work
- Thank you received: 1482
10 Jan 2023 12:55 - 10 Jan 2023 12:57 #261480
Replied by Todd Zuercher on topic Temporarily Disable Signal to Servo Amp
Maybe, instead of disabling the PID it might be better to use one or more mux components to soften the PID's settings so that it doesn't push back so hard as to overload the servo. Simply turning off/on the PID will likely cause it to correct the error with a harsh bang movement when it is enabled. Especially if the error is significant. Also you may have problems with following error alarms and might need to figure out a way to subvert them or set them loose enough to not interfere.
Last edit: 10 Jan 2023 12:57 by Todd Zuercher.
The following user(s) said Thank You: tommylight, hunterlong
10 Jan 2023 18:35 #261517
Replied by andypugh on topic Temporarily Disable Signal to Servo Amp
If you are using Classic Ladder to sequence the tool change then, yes, use it to disable the PID too.
I would suggest a HAL AND2 function so that the PID is active if amp-enable AND the CL output are both true. You need the CL output to default to true and be set false during tool change.
If the Z moves down a bit (onto the plate) then the PID will simply jump back to the commanded position when it is re-enabled. The jump might even help shake the plate free
- hunterlong
10 Jan 2023 19:13 #261518
by hunterlong
Awesome! Now I just need to figure out the details. I have a vague notion of how to wire these things up in HAL. Off to read some tutorials!I included an oscilloscope display during a tool change that didn't fault the amp. The pid is definitely fighting that drawbar pushing down with 2klbs of force!
11 Jan 2023 04:24 #261548
If I am understanding the earlier movies properly, I think that the big sliding plate exists to react the release force, so the amp should maybe be disabled based on the position sensor of that plate.
- hunterlong
11 Jan 2023 07:13 #261557
by hunterlong
Yeah, you are exactly right. Right now I don't have any sensor to indicate that the lock plate is in position, I just fire the air solenoid and assume it is. There is a switch I could wire up that is activated when the plate locks.
Here is a video of the lockbar working, and me accidentally dropping my edge finder because I was videoing and not paying attention
photos.app.goo.gl/AH9BLkDeBQpQepMd8
-Hunter
-Hunter
Time to create page: 0.466 seconds
