Temporarily Disable Signal to Servo Amp
- hunterlong
11 Jan 2023 17:00 - 11 Jan 2023 17:04 #261591
by hunterlong
Replied by hunterlong on topic Temporarily Disable Signal to Servo Amp
Currently I have a custom.hal file that contains
# Load Classicladder
loadrt classicladder_rt
addf classicladder.0.refresh servo-thread
loadusr classicladder --nogui ladder.clp
# Tool change button
net tool-release-btn <= hm2_5i25.0.7i77.0.0.input-05
net tool-release-btn => classicladder.0.in-00
net tool-release-sig-drop classicladder.0.out-00 => hm2_5i25.0.7i77.0.0.output-00
net tool-release-sig-lock classicladder.0.out-01 => hm2_5i25.0.7i77.0.0.output-01
net tool-release-sig-push classicladder.0.out-02 => hm2_5i25.0.7i77.0.0.output-02
Can I just add to this custom.hal file?
loadrt and2
addf and2.0 servo-thread
net z-enable-joint and2.0.in0 <= joint.2.amp-enable-out
net z-enable-ladder and2.0.in1 <= classicladder.0.out-03
net z-enable <= and2.0.out0
net z-enable => pid.z.enable
I doubt that is right. I also attached my custom.hal, my_LinuxCNC_machine.hal, and my_LinuxCNC_machine.ini.
Thanks!
-Hunter
loadrt and2
Thanks!
-Hunter
Last edit: 11 Jan 2023 17:04 by hunterlong.
- hunterlong
11 Jan 2023 17:14 #261594
by hunterlong
I just found this really helpful hal tutorial:http://linuxcnc.org/docs/2.5/html/hal/basic_hal.html
In my my_LinuxCNC_machine.hal I already have this section
So I will need to unlink the joint.2.amp-enable-out and the pid.z.enable pin from the z-enable net before I connect my and2 gate.
so
-Hunter
# AXIS Z JOINT 2
setp pid.z.Pgain [JOINT_2]P
setp pid.z.Igain [JOINT_2]I
setp pid.z.Dgain [JOINT_2]D
setp pid.z.bias [JOINT_2]BIAS
setp pid.z.FF0 [JOINT_2]FF0
setp pid.z.FF1 [JOINT_2]FF1
setp pid.z.FF2 [JOINT_2]FF2
setp pid.z.deadband [JOINT_2]DEADBAND
setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.z.error-previous-target true
net z-index-enable <=> pid.z.index-enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout2-scalemax [JOINT_2]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout2-minlim [JOINT_2]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout2-maxlim [JOINT_2]OUTPUT_MAX_LIMIT
net z-output => hm2_5i25.0.7i77.0.1.analogout2
net z-pos-cmd <= joint.2.motor-pos-cmd
net z-enable <= joint.2.amp-enable-out
so
loadrt and2
unlinkp joint.2.amp-enable-out
unlinkp pid.z.enable
-Hunter
- hunterlong
11 Jan 2023 17:32 - 11 Jan 2023 17:46 #261596
by hunterlong
That worked! other than a few typos like and2.0.out0 is actually and2.0.out.
However, now as soon as I disable the PID with the pid.z.enable pin I get a following error in about 3 seconds.
Haven't tried while the z-axis was locked though. Maybe I won't get a following error.
EDIT: I can actually see the z-axis slowly drift down when I disable it, so no wonder I am getting a following error.
-Hunter
-Hunter
Last edit: 11 Jan 2023 17:46 by hunterlong.
- hunterlong
11 Jan 2023 20:14 - 11 Jan 2023 20:22 #261616
by hunterlong
It now works great! Thanks for all the help.
See the images and videos in this link (I added descriptions to each photo) for before/after: photos.app.goo.gl/A1DKWGkwW2Jyicae8
I can still get a following error if the z-axis is too high and travels down a bit before it hits the lock plate. Might try to fix this later, but as long as I get the z-axis height exactly right it works great. Tested like 10 times and no stuck lock plate, no servo driver faults!
-Hunter
-Hunter
Last edit: 11 Jan 2023 20:22 by hunterlong.
- Thank you received: 7488
11 Jan 2023 21:00 #261619
Replied by tommylight on topic Temporarily Disable Signal to Servo Amp
You cam set the min_ferror to a bit higher value in the ini file to prevent joint error.
The following user(s) said Thank You: hunterlong
- Thank you received: 1480
12 Jan 2023 21:20 #261741
Perhaps you are trying to make this entirely too complicated. You say there is/was a switch that was triggered when the lockplate is enguaged. I wouldn't be at all surprised if the original control simply ran the servo amp's enable signal through that switch. So that when the locking plate was engaged the amp was automatically disabled. You could either do the same (and leave Linuxcnc unaware) or bring that signal into hal to disable the PID with a piece of hal logic.
Replied by Todd Zuercher on topic Temporarily Disable Signal to Servo Amp
Yeah, you are exactly right. Right now I don't have any sensor to indicate that the lock plate is in position, I just fire the air solenoid and assume it is. There is a switch I could wire up that is activated when the plate locks.
Here is a video of the lockbar working, and me accidentally dropping my edge finder because I was videoing and not paying attention
photos.app.goo.gl/AH9BLkDeBQpQepMd8
-Hunter
- hunterlong
12 Jan 2023 21:25 #261742
by hunterlong
You know that is a really good idea Todd. Why didn't I think of that!
However, it is working now pretty well so I will keep that in mind in case I start having trouble again!
-Hunter
-Hunter
Time to create page: 0.169 seconds
