Estop, external and internal with physical relay
- Mattias
07 Nov 2024 10:46 - 07 Nov 2024 17:39 #314024
by Mattias
Estop, external and internal with physical relay was created by Mattias
Hi guys,
I have been trying for a couple of days to get the e stop to work on my diy cnc router.
I have an safety circuit which connects 24v supply to a relay(which switches on motor powers). Output 00 of mesa card 7i95t and 4 physical estop NC are wired in series to this safety circuit.
In parallel i have wired this circuit to mesa input 01.
Here is my hal io code.
I have many more attempts but this one came the closest. It triggers the relay for a second but does not 'stick'.
I want to reset with gui request enable en trip the circuit with either estop external button or software internal button on gui.
Can anybody please point me in the right direction, i have tried so many things and i get maybe more confused by the day
# E-Stop Chain
loadrt estop_latch count=2
addf estop-latch.0 servo-thread
addf estop-latch.1 servo-thread
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset => estop-latch.1.reset
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net latch0-faultout estop-latch.0.fault-out
net latch1-okin estop-latch.1.ok-in <= estop-latch.0.ok-out => hm2_7i95.0.ssr.00.out-00
net latch1-faultin estop-latch.1.fault-in <= hm2_7i95.0.inmux.00.input-01-not
net latch1-out estop-latch.1.ok-out => iocontrol.0.emc-enable-inI have many more attempts but this one came the closest. It triggers the relay for a second but does not 'stick'.
Last edit: 07 Nov 2024 17:39 by Mattias.
- Thank you received: 5336
07 Nov 2024 12:45 - 07 Nov 2024 12:53 #314030
Replied by PCW on topic Estop, external and internal with physical relay
if estop-latch.N.ok-out goes false, one of these must have changed:
estop-latch.N.ok-in goes false
estop-latch.N.fault-in goes true
So I would watch these in halshow or halscope to see whats happening.
I also don't understand why you have two estop latches. It seems that one
should be sufficient (adding some logic if you need to add fault inputs or OK inputs)
Last edit: 07 Nov 2024 12:53 by PCW.
The following user(s) said Thank You: Mattias
- Unlogic
- Thank you received: 133
07 Nov 2024 12:54 #314031
by Unlogic
Replied by Unlogic on topic Estop, external and internal with physical relay
I documented my e-stop setup using an external safety relay in the post linked below:
forum.linuxcnc.org/12-milling/50559-opti...rsion?start=0#284533
Maybe it will help you get your setup up and running.
- Mattias
07 Nov 2024 17:50 #314052
by Mattias
I saw you used the oneshot function, i have tried implementing it like you did but no succes. I will try again once i got the time.
Thanks, cheers
Replied by Mattias on topic Estop, external and internal with physical relay
Hi, thank you for your reply. I have read your documents on your build, very impressive, thanks for the detailed sharing and documenting.I documented my e-stop setup using an external safety relay in the post linked below:
Thanks, cheers
- Mattias
07 Nov 2024 17:56 #314053
by Mattias
I have tried with two latches, with the idea that one will be for external estop (input 00) and the other for software internal estop (user enable out).
I also tried with one, linking the ok-in for user-enable out and fault-in to input00 external estop. No succes.
I will keep trying, thanks.
If you have any more sugestions i would be happy to hear them.
Hi, thank you for your quick reply. I have been looking at these halshow/scope bits but could not get it to click.if estop-latch.N.ok-out goes false, one of these must have changed:
- Mattias
07 Nov 2024 18:01 #314056
by Mattias
Yes please, i tried it myself but i guess that is not possible. Thanks!Should we delete the two duplicate replies above without the quoted text?
- Thank you received: 7504
07 Nov 2024 19:45 #314059
Replied by tommylight on topic Estop, external and internal with physical relay
Done, thank you, i will delete this and the one above this after you get a chance to read it to keep this topic clean.
- Benb
- Thank you received: 61
15 Nov 2024 20:38 #314582
by Benb
Replied by Benb on topic Estop, external and internal with physical relay
The attached control circuit will disable the spindle and servos of the machine if an Estop push button (PB) is pressed or change tool is requested. The arrangement is combination of both software and external hardwired circuit.
To stop any movement of the machine, the approach uses estop and reset pins of the halui component and redundant hardwired external circuit to disable any movement of the machine. The interface between the software and the hardwired circuit is done through digital I/O (2 or 3 inputs and two outputs).
Operation of this system is follows:
If an Estop PB is activated or tool change is requested machine will go into an Estop state.
On the left side of the sheet is the electrical schematic. Showing use 5 relays. If you decide to use this circuit you need to determine the number of contacts normally open and normally closed before ordering the relays. The MCR contacts connection to servos and VFD are hardware dependent (if you need help with this part of the diagram ask)
On the right side is a postgui block diagram reflecting net listing of hal file see below.
# Load realtime Components and their counts
loadrt and2 count= 2
loadrt flipflop count= 1
loadrt or2 count= 1
# Add functions to threads
addf and2.0 servo-thread
addf and2.1 servo-thread
addf flipflop.0 servo-thread
addf or2.0 servo-thread
# Connect Pins with Wires
# signal/wire connected Pins
net estop.activate.sig halui.estop.activate and2.1.in1 flipflop.0.out
net estop.is-activated.sig halui.estop.is-activated and2.0.in1 flipflop.0.reset hm2-7i92.0.7i77.0.0.output-00
net estop.reset.sig halui.estop.reset and2.0.out
net external.reset and2.0.in0 hm2-7i92.0.7i77.0.0.input-01
net external=estop flipflop.0.set hm2-7i92.0.7i77.0.0.input-00
net t.prepare.loop iocontrol.0.tool-prepared iocontrol.0.tool-prepare
net t.xch.done hal_manualtoolchange.changed iocontrol.0.tool-changed
net tool-changed or2.0.in0
net tool-xch.request hal_manualtoolchange.change iocontrol.0.tool-change hm2-7i92.0.7i77.0.0.output-01
net tool.changed or2.0.out and2.1.in0
net tool.changed.button hal_manualtoolchange.change_button and2.1.out
net tool.number hal_manualtoolchange.number iocontrol.0.tool-prep-number
net ui.tool.change.pb or2.0.in1
- If only Estop is activated, operator is required to press push button reset to enable spindle and servos
- If tool change is requested, operator is required to change the tool, press tool changed PB (either hardwired or UI) and press reset PB to reset the estop and continue operation. (I know operators don’t like to press two buttons sequentially in certain order, but for their hands and fingers sake the extra mental challenge makes it worthwhile, I think!.
loadrt or2 count= 1
Time to create page: 1.059 seconds
