Button for Y-axis speed
- Muecke
- Thank you received: 93
19 Jan 2025 16:56 #319385
by Muecke
Button for Y-axis speed was created by Muecke
Hello everyone,
I have a push button that should move 50% speed on the y-axis.
LinuxCNC: 2.9.1 (is correct)
Hardware:
Mesa 7i95
Push-button => www.amazon.de/dp/B08B5YC29H
I have connected it to input pin 7 (hm2_7i95.inmux.00.input-07-not).
Hal-Meter
Button not pressed => TRUE
Button pressed => FALSE
No matter what I enter in my HAL files, the Linux CNC no longer starts
How do I have to write this into the HAL?
Button pressed == axis Y with 50% speed in positive direction
My current INI & HAL data:
Sorry, I had already opened a post in the German forum, but unfortunately without a response, so this time in the English section. Hoping that someone can help me further.
forum.linuxcnc.org/42-deutsch/55066-tast...nuxcnc-2-8-einbinden
Greetings Mücke
Hardware:
Mesa 7i95
Hal-Meter
Greetings Mücke
- Muecke
20 Jan 2025 07:01 - 20 Jan 2025 10:58 #319445
by Muecke
Replied by Muecke on topic Button for Y-axis speed
If I have understood correctly, I have now installed the input pin (at least there is no longer an error), but when the button is pressed, nothing moves on my machine
What have I forgotten?
Gruß Mücke
[EDIT]
I found my error, I included a joystick and there were certain things connected that led to the conflict.
I have temporarily removed the joystick.
My HAL now looks like this.
# Datei: io.hal
# Fußschalter Y-Achse (Footswitch) #
# Connect button to Mesa input 7 #
# Move foot switch Y-axis #
# Move in positive direction #
# Joint to Axis
# Joint 0 ==> Axis Z
# Joint 1 ==> Axis Z
# Joint 2 ==> Axis X
# Joint 3 ==> Axis Y
# Joint 4 ==> Axis C
# Hal-Meter
# Pin ==> hm2_7i95.0.inmux.00.input-07-not
# Button not pressed => TRUE
# Button pressed => FALSE
# Verknüpfe die Taste mit dem Jog-Enable-Signal der Y-Achse
net Footswitch joint.3.jog-enable <= hm2_7i95.0.inmux.00.input-07-notGruß Mücke
[EDIT]
# Link the button to the jog enable signal of the Y-axis
net Footswitch halui.axis.y.plus <= hm2_7i95.0.inmux.00.input-07
# Set speed
setp halui.axis.jog-speed 1200
Last edit: 20 Jan 2025 10:58 by Muecke.
Time to create page: 0.235 seconds
