caxis.comp - How to freewheel axis/spindle?
1 year 8 months ago - 1 year 8 months ago #320482 by jpg
Attached is block diagram showing a spindle orient example. I also attached the hal netlist.PID, limit2, offset, … etc parameters values are not complete, you will need to figure them out as you experiment.
Hello, could you tell me what OFFSET is used for in your configuration, I'd like to know more about it, on which machine do you use it?
Bravo SPUMCO for your tests on the C axis, it's really a very special configuration, thank you for sharing, I admire your perseverance!
Last edit: 1 year 8 months ago by jpg.
1 year 8 months ago #320489 by spumco
@jpg-
What OFFSET are you referring to?
1 year 8 months ago #320493 by jpg
loadrt offset count= 1
addf offset.0.update-output servo-thread
addf offset.0.update-feedback servo-thread
setp offset.0.offset 1
net pid-orient-pos-cmd offset.0.out pid.1.command
1 year 8 months ago #320494 by spumco
What you posted is from @Benb's suggestion a few posts earlier, not part of my configuration.
1 year 8 months ago #320495 by jpg
yes, that's right, I wanted to understand what this component brings.
1 year 8 months ago #320497 by spumco
Would you mind starting a new thread for tangential questions?
The following user(s) said Thank You: jpg
Time to create page: 0.095 seconds
