Semi-realtime hal component
- Serhii
05 Feb 2025 05:09 #320722
by Serhii
Semi-realtime hal component was created by Serhii
Dear community,
I have the following setup
Computer Debian RT XYZ closed
Vision <==(ethernet)==> Linux CNC <=========> Mesa 7i96 <=========> loop rotating
PC PC with dual platform
(CVPC) ethernet (CNCPC) (no encoders)
CVPC independently processes visual information in realtime (15-20FPS or 50-65ms) and computes the target position for the rotating platform.
This information is communicated via ethernet to CNCPC using low-latency messaging library (e.g. ZeroMQ) that has support in both python and C++.
Based on the target position information the rotating platfrom can:
a) Start movement to the given position
b) Abandon the last target position (even if the move hasn't finished yet) and update it with the newly available data. Start rapid movement to the target position.
My questions are mostly:
1. Should my component be realtime or non-realtime. Even though 15-20FPS is guaranteed, the exact timings when new position measurements arrive are not strictly defined. Communication in ZeroMQ can be blocking, i.e. wait on the function call and return if a message has arrived or non-blocking, i.e. check for new messages in a loop. So, the arrival of new data is not realtime, but target position update should be performed asap.
2. How can I update the target position in HAL (e.g. with axis or motion) such that velocity and acceleration are updated properly? As mentioned above the last movement might be still ongoing, so it has to be interrupted and the new move started.
I did my best and went through the documentation and the following forum topics:
forum.linuxcnc.org/24-hal-components/409...position-in-realtime
forum.linuxcnc.org/38-general-linuxcnc-q...ontrol-with-linuxcnc
forum.linuxcnc.org/38-general-linuxcnc-q...r-cnc-control-in-c-c
forum.linuxcnc.org/24-hal-components/528...bot-arm-in-real-time
forum.linuxcnc.org/38-general-linuxcnc-q...391-realtime-control
Unfortunately, I haven't found the recipe suitable for me. Also, there is a chance I might have overlooked the right solution cause I am still quite new to the LinuxCNC ecosystem. Any help is appreciated. Thank you!
- Serhii
05 Feb 2025 06:24 #320736
by Serhii
Replied by Serhii on topic Semi-realtime hal component
Sorry, the tabs got messed up.
Here is the setup once again
- meister
- Thank you received: 502
05 Feb 2025 09:05 #320753
by meister
Replied by meister on topic Semi-realtime hal component
you can take a look at this (non-realtime) component,
there i use sliders in python(qt5) to move my robot-joints.
it can also change the target position while moving, like you need.
github.com/multigcs/riocore/blob/main/ri...s/robojog/robojog.py
the script is not big and you already have an insight or you can use it as a basis, throw out qt and simply replace the inputs with ZeroMQ
The following user(s) said Thank You: Serhii
- Thank you received: 2177
05 Feb 2025 09:13 #320754
Replied by Aciera on topic Semi-realtime hal component
Are these positional updates coming in during execution of a gcode program or while an individual MDI command is being executed?
There has been a short discussion about a similar project recently:
forum.linuxcnc.org/38-general-linuxcnc-q...robot-control#319033
- Serhii
05 Feb 2025 14:17 #320787
by Serhii
Thanks for your reply!
The solution seems promising. I went through the code and I see how you control the axes using jog-counts like with MPG. The only doubt I have is that whether these jog-counts will respect the coordinated motion of XY axes. Say if I change both counts at the same time in my component, will it result in synchronous movement of X and Y and will it do proper velocity & acceleration/deceleration, or will it be just a linear motion with constant velocity? Please let me know if you have any idea. Thanks!
- Serhii
05 Feb 2025 14:51 #320789
by Serhii
I went through the topic you referred to and it seems quite suitable for my needs. In essence, this is very similar to what the other commentator has suggested. But as compared to MPG these external offsets can actually rely on coordinated motion planners when modifying g-code controlled motion.
Now answering your question, this stream of coordinates is the only source of movement commands for the rotating platform. Hence, I can implement it the way the original author of the topic you referred to has done (i.e. 'M66' + 'G1' g-code commands in loop) or just issuing python/c++ MDI commands in a loop. In my understanding the algorithm might look like this:
1. Run G1 command in loop. Target point is the last available position received
2. If new data comes and the motion is still ongoing (e.g. check 'motion.motion-type') -> compensate the target position with 'eoffset-counts'
3. If new data comes and the motion has stopped -> signal to M66 input
4. If new data comes and the target position has not changed -> do nothing
The only thing I am not sure about is what would be my final position with offsets enabled. Say I finish one G1 command with the offset, and for the next one in the loop the same offset will still apply, right? So I have to set it manually to zero (e.g. with 'eoffset-clear'). Please let me know if you think it makes sense what I have written and whether you have any additional comments/suggestions. Thanks!
- meister
05 Feb 2025 15:32 #320795
by meister
I use the same approach here:
www.youtube.com/shorts/VGWusrDVHlg
I think that's even closer to what you have in mind
github.com/multigcs/riocore/blob/main/ri...ons/camjog/camjog.py
- Serhii
29 May 2025 16:12 #329386
by Serhii
Just a short reply to end the thread.
At the end of the day I used external-offsets and it worked like a charm. No g-code has to run at all in my current setup.
linuxcnc.org/docs/html/motion/external-offsets.html
It's very similar to the jog-counts/jog-scale approach that was suggested here too, but I wasn't sure whether I would be able to control acceleration in that case. So I started with external-offsets and that was enough.
Thanks everyone for the advice!
Time to create page: 0.192 seconds
