halui.mdi-command-NN pins not showing up
- xunil
30 Aug 2025 01:23 #334143
by xunil
halui.mdi-command-NN pins not showing up was created by xunil
Hoping someone can point out the probably obvious error in my configs that is causing halui.mdi-command-NN pins not to be created. The halui component loads and the rest of halui's normal pins show up in the HAL Configuration tree; in the [HAL] section I have the HALUI = halui line; I've made sure the [HALUI] section in the INI file exists and that there are MDI_COMMAND entries under that heading, but still no joy. Can someone see what I've missed?
Thanks.
Thanks.
- Benb
- Thank you received: 61
30 Aug 2025 17:32 #334150
by Benb
Replied by Benb on topic halui.mdi-command-NN pins not showing up
An MDI command can be executed by using halui.mdi-command-00
Here is an example showing how it 's done:
linuxcnc.org/docs/html/gui/halui.html
- xunil
30 Aug 2025 18:34 #334153
by xunil
Replied by xunil on topic halui.mdi-command-NN pins not showing up
I’m aware of how it’s _supposed_ to work, my question is what I’m doing wrong in my configs that make halui not expose mdi-command-00 etc pins despite the presence of MDI_COMMAND entries in the [HALUI] INI section, and HALUI=halui in the [HAL] section?
- MaHa
- Thank you received: 241
30 Aug 2025 19:20 #334154
by MaHa
Replied by MaHa on topic halui.mdi-command-NN pins not showing up
Just in case you are not aware that in the # Syringe section in your postgui.hal everything regarding mdi-command is commented out.
- xunil
30 Aug 2025 19:30 - 30 Aug 2025 19:37 #334155
by xunil
Yeah, I commented those out to get LinuxCNC to start so I could look at the halui component in halshow, to see if maybe the pins were numbered differently than I expected or something. With those lines uncommented LinuxCNC won't start, since the mdi-command-NN pins don't exist.
Thanks for mentioning it though, I've certainly had forest-for-trees errors like that before where another pair of eyes spotted the problem immediately.
Last edit: 30 Aug 2025 19:37 by xunil.
- MaHa
30 Aug 2025 21:49 #334158
by MaHa
There is </vbox> missing at the end of of the .xml file
- xunil
31 Aug 2025 00:15 #334165
by xunil
Thanks for the heads up! I don't think that would affect whether the mdi-command-NN pins would show up or not; even if don't load the PyVCP panel, I still don't see the pins exposed by halui.
- JT
- Thank you received: 600
31 Aug 2025 12:58 #334179
by JT
Replied by JT on topic halui.mdi-command-NN pins not showing up
There is something weird going on, I'm trying to duplicate the issue and some configurations mdi works and some do not.
JT
JT
- JT
31 Aug 2025 13:06 #334181
by JT
Changing A to X and the mdi commands show up, changing back to an angular axis and the mdi commands don't show up.
JT
JT
31 Aug 2025 17:10 #334194
Any clues from starting LinuxCNC at the command line? It sounds like it is giving up before parsing the MDI_COMMAND lines.
Replied by andypugh on topic halui.mdi-command-NN pins not showing up
Thats more than a bit wierd.Changing A to X and the mdi commands show up, changing back to an angular axis and the mdi commands don't show up.
